Mr.Meseeks Says 'All Done!'
A project log for WITCH-E Decimal Based Computer
Document and create a modern replica of the Harwell Dekatron computer known as the WITCH
daves-dev-labDave's Dev Lab 10/19/2017 at 22:340 Comments
The new keypad encoder is 'All Done!'. It mates up directly with the male headers on the keypad PCB, so no need for cables to connect the two. When I design the laser cut acrylic for this section, I'll need to leave some tolerance for the screw holes so I can make sure it sits snuggle together.
