A little of ternary theory - we will use "balanced" one where our 3 values are -1, 0 and +1 (NOT 0,1,2). Atomic bit of ternary information usually called trit. And lets call 3 trits a triad. 1 trit could be in 3 states, 2 trits could be in 9 states (3^2) and 3 trits could be in 27 states (3^3). Triad may represent a number from -13 (9*(-1)+3*(-1)+1*(-1)) to +13 (9*(+1)+3*(+1)+1*(+1)), but how we should write this numbers in ternary form? -1-1-1 and +1+1+1 are not practical. So we came up with alphabetical labels for ternary values: +1 is labeled P (positive), 0 is labeled O (it's letter O, but we call it "neutral") and -1 is labeled N (negative), So -1-1-1 (number -13) could be written as NNN and +1+1+1 (number +14) could be written as PPP. Obviously 000 (number 0) is OOO :)
Now about 3niti alpha architecture (mostly designed in 2004). It has 3-trit data (27 possible values from -13 to +13), 9-trit address (to access up to 19683 cells) and 9 registers (coded by 2 trits that could be represented by numbers from -4 to +4):
N (-4): triad from memory addressed by DPn;
O (-3): triad from memory addressed by DPo;
P (-2): triad from memory addressed by DPp;
F (-1): flag register: RSF (Result Sign Flag), DPF (Data Pointer Flag), BCF (Borrow Carry Flag);
A (0): accumulator register;
B (+1): auxiliary register;
L (+2): lower triad of current DP register;
M (+3): middle triad of current DP register;
H (+4): higher triad of current DP register.
There are THREE 9-trit DP (data pointer) registers - DPn, DPo, DPp that are available through registers L/M/H when flag DPF has corresponding value (N, O, P respectively). Also there is 9-trit register PC (program counter) and this architecture doesn't have a stack, so no register SP.
Instruction set is 27 opcodes ($ means one triad in instruction parameters):
TernaryDecimalMnemonicDescription
NNN-13SANSave value from register A to N (memory cell with address DPn)
NNO-12SAOSave value from register A to O (memory cell with address DPo)
NNP-11SAPSave value from register A to P (memory cell with address DPp)
NON-10SAFSave value from register A to F
NOO-9SPCDSave value from PC (program counter) to current DP (data pointer)
NOP-8SABSave value from register A to B
NPN-7SALSave value from register A to L (lower triad of current data pointer)
NPO-6SAMSave value from register A to M (middle triad of current data pointer)
NPP-5SAHSave value from register A to H (higher triad of current data pointer)
ONN-4RLARotate register A to the left through flag BCF
ONO-3ADDAdd register A with B and flag BCF, save result to A and BCF, modify sign flag RSF
ONP-2RRARotate register A to the right through flag BCF
OON-1LAI $Load register A from immediate triad
OOO0ADI $Add register A with immediate triad and flag BCF, save result to A and BCF, modify sign flag RSF
OOP1OPA $Perform unary "tritwise" operation over A (function is defined by immediate triad), modify sign flag RSF
OPN2LDI $ $ $Load current DP (data pointer) by immediate 3 triads (higher triad, middle triad, lower triad)
OPO3JMP $ $ $Jump to address (copy to PC) set by immediate 3 triads (higher triad, middle triad, lower triad)
OPP4OPB $ $ $Perform binary "tritwise" operation over A and B, save result to A (function is defined by immediate 3 triads), modify sign flag RSF
PNN5LANLoad register A by value from N (memory cell with address DPn)
PNO6LAOLoad register A by value from O (memory cell with address DPo)
PNP7LAPLoad register A by value from P (memory cell with address DPp)
PON8LAFLoad register A by value from F
POO9LPCDLoad PC (program counter) by value from current DP (data pointer)
POP10LABLoad register A by value from B
PPN11LALLoad register A by value from L (lower triad of current data pointer)
PPO12LAMLoad register A by value from M (middle triad of current data pointer)
PPP13LAHLoad register A by value from H (higher triad of current data pointer)
Control panel for 3niti alpha (designed in 2008) consists of 2 rows:
Top horizontal row of 15 "ternary" red-green light indicators:
Bottom horizontal row of 15 "ternary" slide switches:
P (top position) - using specified address write data to the memory (data lights display this 3-trit data)
O (neutral position) - ignore address and data switches (data lights display data from memory address PC)
N (bottom position) - ignore data switches and display data from specified address
P (top position) - interrupt main program, save current PC and jump to specified address
O (neutral position) - do not disturb working program
N (bottom position) - stop subprogram and restore PC to return to main program
P (top position) - execute one step of the program
O (neutral position) - pause mode
N (bottom position) - run program from current position
