Primary objectives complete
A project log for Altair 8800 front panel Ardiuno shield
A very small fully-functional interface for an Arduino Due emulating an Altair 8800
justin-davisJustin Davis 03/08/2017 at 17:431 Comment
I have my primary objectives of switches and lights done. And it works!
There are two errors which I discovered. One pairs of pins going to A4 and A5 are swapped in the footprint artwork for the dual row connector. So those LEDs are swapped. Not a big deal - I can hack the software to get them to display correctly. The second is I have my STOP/RUN switch backwards. Again, I can swap it in software. If I do another board spin, I will fix those errors and the via solder mask problem.
I have kill-the-bit up and running and it looks like it's working ok. I haven't finished checking every LED and switch, so there may be more hidden errors. Next is get the microSD card reader up and running so I can have disks!
Dave's Dev Lab wrote 03/08/2017 at 21:13 point
Awesome!
