I'm hoping to make a device which is very functional while also being hacker-friendly. One of the most frustrating things about many DSP effects units is the lack of algorithm control. They may give you a reverb effect with many parameters, but what if you want reverb in a pyramid instead of a large room? I hope to make a pedal which is transparent.
Currently working on the analog front end, data converters and DSP. The cloud-interface appears to be relatively easy with spark core!
Similar projects:
kickstarted programmable pedal: http://hoxtonowl.com
commercial programmable pedal: http://line6.com/tcddk/
arduino programmable pedal: http://www.electrosmash.com/pedalshield
programmable pedal: http://howleraudio.com/frontpage/
Luke
Pablo Antonio Camacho Jr.
andriy.malyshenko
barryjosephcullen
