Board and Schematic - Part 1/2
03/28/2017 at 09:16 • 0 commentsA bit more I have done now, Part1 is so far finished and can be ordered, minor improvements are still missing.
I have decided for two Capatzitive buttons which are controlled with an AT42AT1010, as a first display is a 0.96 "OLED which can be replaced by a 1.3" OLED.
I have noticed something to buildability and the components so that they can be soldered by hand.
Part2 - Tested
03/17/2017 at 09:10 • 0 commentsPart2 is tested and functional, add PCB data to the Downloads
Part2 - Arrived
03/15/2017 at 10:03 • 0 commentsArrived by OSH Park, looks really chic, unfortunately I will come in the coming days for placement and testing.
Brainstorming
03/10/2017 at 18:34 • 0 commentsA small drawing as I imagine, the switch box has a depth of 60mm, the PCB stack sticks ~ 26mm inside, ~ 34mm left for the cabling.
Status
03/04/2017 at 08:37 • 0 commentsI'm planning on Part 1 (Switch and Display), Part 2 (WLAN and Logic) is Ordered at #OSHPark.
So I have to be patient.
