The challange
It's really useful at your work or at your home to see the invisible! Objects and living beings radiates heat, which offers very valuable information in many cases. However the that radiation in invisible for humans.
Use cases
Using the thermal camera you will be able to detect:
- Leaks in wall or roof
- insufficient or damaged insulation
- electrical problems, short circuits
- overheated electrical or mechanical components
- discovering rodents, wasp nests, etc...
- issues with farm animals or pets
Pocket size Thermal camera
Features:
- FLIR Lepton Thermal Image Sensor 80*60 pixel
- Full color OLED display 160*128 pixel
- Atmel ARM Cortex M0+ CPU ( SAMD21 )
- SD card
- USB connection
Block diagram of the system:
License
The device is licensed under the GNU General Public License v3.0.
x-labz
Fabien-Chouteau
mircemk
How can I make on of these? Awesome project!
