Back to this project !
A project log for micro HTTP server in C
Connect your browser to your smart devices, using a minimalist HTTP compliant server written in POSIX/C
yann-guidon-ygdesYann Guidon / YGDES • 04/15/2020 at 16:34•0 Comments
The confinement is a good period to refresh this software-only project and here is the new version !
HTTaP_src.20200415.tgz
3 years after the last version, I have cleaned up the TCP/IP code. IPv6 handling is removed because never used in practice, I added more checks and a few portability helpers that would help with MacOS and Win32. I also simplified several cases where strlen() can be replaced by sizeof() because the strings are constants.
I have a few more days to work on this and hopefully there will be more significant enhancements !
BTW, does this new version work on your computer(s) ?
