New version : Firefox vs Chromium-browser
A project log for micro HTTP server in C
Connect your browser to your smart devices, using a minimalist HTTP compliant server written in POSIX/C
yann-guidon-ygdesYann Guidon / YGDES • 04/26/2020 at 19:15•0 Comments
The latest version is out and solves quite some problems !
However things are a bit weird when it is used by "modern browsers". I have found no problem with links or lynx but these are text-based browsers that display only one page and don't load external resources, so it gets one elements and the connection times out... Since they don't really support JavaScript, they are not considered, anyway.
Firefox
This one is quite good but even if it is the recommended one, there are still wrinkles here and there.
Conclusion: Apparently, Firefox is smart enough to see that if one connection/socket is slammed on its face, the pending requests can/should go to the other working socket(s). Simple HTTaP/? requests seem to work rather smoothly.
So at least there is something that works, even though some behaviours need more investigations.
Chrome/Chromium-browser
It can do simple things right but its tries so much to optimise things that it sometimes feels like a fanatic or a lunatic. Maybe it was really too focused on working with the websites of the Alphabet Group.
Let's start with an easy case : GET /?PING is fine, with the little detail that apparently, Cache-Control: max-age=200 is not understood. So WHAT is required by Chrome to keep that data in cache ? Anyway at least the function is performed (though at least one parallel connection is opened and slammed) but wait for the rest.
Let's try to load a web page with about a dozen of external links.
10 parallel sockets are opened and slammed, 5 resources (including index.html) are loaded, in a seemingly random order, probably because of the extra sockets that contain the requests. The main socket closes from timeout without getting the missing ten requests. What the... ???
Setting the HTTAP_TCP_BACKLOG #define to 0 or 1 makes the situation even worse, the page loads slooooowly and incompletely... Chrome won't get the clue !
There is still the possibility to limit the number of concurrent open sockets on a webserver but it requires a user manipulation on the browser and it's too specific and intrusive. Meanwhile HTTP1.1 doesn't seem to specify anything about explicitly limiting the number in the headers
And then, there is the question : WHY does Firefox get the clue but Chrome won't ? I suspect it's because they use different queuing algorithms but this does not help me so far.
Remediation : this problem seems to affect webpages while the HTTaP parts doesn't seem to be affected.
I hope that I can solve this problem soon anyway...
Edit :
I just found why FF sends empty packets !!!
It happens when you hover the cursor over a local link...
Firefox speculates that you will click on it and prepares the connection !
