HTTaP_src.20210106.tgz
fixed poll() race condition that would exit the server, see <a target="_blank" rel="noopener noreferrer" href="https://hackaday.io/project/20042/log/187866">https://hackaday.io/project/20042/log/187866</a>
x-compressed-tar - 51.47 kB - 01/06/2021 at 21:28
Download
HTTaP_src.20200515.tgz
speed test
x-compressed-tar - 51.37 kB - 05/16/2020 at 00:19
Download
HTTaP_src.20200514.tgz
Better graceful close, user call wrapper !
x-compressed-tar - 51.00 kB - 05/15/2020 at 03:30
Download
HTTaP_src.20200513.tgz
more JS wizardry, and graceful close of the page, among other things !
x-compressed-tar - 50.69 kB - 05/13/2020 at 03:03
Download
HTTaP_src.20200511.tgz
JS client sustains an exclusive connection and other later connections fail as they should. Progressive load of extra images is ok.
x-compressed-tar - 49.86 kB - 05/11/2020 at 01:01
Download
HTTaP_src.20200509.tgz
JS client emerging
x-compressed-tar - 48.85 kB - 05/09/2020 at 00:31
Download
HTTaP_src.20200506.tgz
session id : ok
x-compressed-tar - 46.86 kB - 05/05/2020 at 23:53
Download
HTTaP_src.20200504.tgz
itos(), /?ping=&gt;timeout
x-compressed-tar - 45.64 kB - 05/04/2020 at 00:32
Download
HTTaP_src.20200502.2.tgz
more close() bugs, one buffer removed
x-compressed-tar - 42.46 kB - 05/02/2020 at 02:38
Download
HTTaP_src.20200501.tgz
weird close() bugs solved !
x-compressed-tar - 42.25 kB - 05/01/2020 at 05:03
Download
HTTaP_src.20200428.tgz
more docs, less bugs
x-compressed-tar - 41.81 kB - 04/28/2020 at 00:17
Download
HTTaP_src.20200427.tgz
Better than the last version ;-)
x-compressed-tar - 40.54 kB - 04/27/2020 at 02:02
Download
HTTaP_src.20200426.4.tgz
x-compressed-tar - 40.24 kB - 04/26/2020 at 18:46
Download
HTTaP_src.20200426.tgz
reworked system !<br>needs more work but minimal example is functional.<br>one mis-feature needs to be investigated before going further...
x-compressed-tar - 40.00 kB - 04/26/2020 at 03:22
Download
HTTaP_src.20200424.interim.tgz
Not an official revision, but interesting things happen inside !
x-compressed-tar - 40.44 kB - 04/24/2020 at 05:20
Download
HTTaP_src.20200416.tgz
much better version, license added, bugs removed, better MIME handling, more control of cache...
x-compressed-tar - 37.40 kB - 04/16/2020 at 03:30
Download
HTTaP_src.20200415.tgz
refreshed version
x-compressed-tar - 9.21 kB - 04/15/2020 at 08:31
Download
HTTaP_src_20170401.tgz
Timeout, connection persistence, file serving, etc. are implemented, with crude MIME support through links
x-compressed-tar - 7.75 kB - 04/01/2017 at 08:09
Download
HTTaP_src.20170327.tgz
New revision : english comments and variable names, split files, example file... Timeout still not implemented.
x-compressed-tar - 4.61 kB - 03/27/2017 at 09:53
Download
test_XHR.html
tests serv_11_CORS.c (change the URLs in the source code to point to your own server)
HyperText Markup Language (HTML) - 1.58 kB - 02/26/2017 at 07:05
Download
serv_11_CORS.c
Includes CORS-compliant headers
text/x-csrc - 11.29 kB - 02/26/2017 at 07:05
Download
serv_10_timer.c
incomplete implementation of the timeout.
x-csrc - 11.09 kB - 02/26/2017 at 05:08
Download
serv_9_blocant.c
can change on-the-fly between polling and blocking mode
x-csrc - 11.03 kB - 02/25/2017 at 23:08
Download
serv_8_change-user.c
Change the running user and drop access rights (safety if you need to serve files)
x-csrc - 10.68 kB - 02/25/2017 at 23:08
Download
serv_7_config.c
x-csrc - 8.31 kB - 02/25/2017 at 23:08
Download
serv_6_1ou0.c
a dumb server that understands the addresses 1 and 0
x-csrc - 7.36 kB - 02/25/2017 at 23:08
Download
serv_6_dualmode.c
can be compiled for either polled or blocking mode
x-csrc - 7.15 kB - 02/25/2017 at 23:05
Download
serv_5_IPv6.c
x-csrc - 7.00 kB - 02/25/2017 at 22:23
Download
serv_4_FSM.c
x-csrc - 4.62 kB - 02/25/2017 at 22:23
Download
serv_3_nonblock.c
x-csrc - 3.58 kB - 02/25/2017 at 22:23
Download
serv_2_reuseAddr.c
x-csrc - 2.83 kB - 02/25/2017 at 22:23
Download
serv_1_simple.c
x-csrc - 2.49 kB - 02/25/2017 at 22:23
Download
