USB Disconnect Leaks Fixed
A project log for USB Interruptor
Press the button to momentarily disconnect a USB device
paul-stoffregenPaul Stoffregen 02/26/2017 at 22:400 Comments
Exciting news: with this commit (and several others just before it), I've finally managed to free all the memory resources when a USB device disconnects.
I just disconnected and re-enumerated a USB keyboard 60 times in a row. Previously I could only do this a few times (and a week ago not at all due to other limitations) before all the slots in the memory for devices & pipes were used up.
Now all the resources are being returned, or at least all the ones in use for this simple test. Still so many more cases to consider....
