Stereo Audio DAC Board Designed
A project log for Anacon-xC
Analog video console based on XMOS xCore with VGA/NTSC/PAL video output and PS/2 mouse/keyboard input. 32-bit scanline-based rendering.
kevin-h-pattersonKevin H. Patterson • 03/09/2017 at 07:22•1 Comment
Got a mini adapter board designed and ordered for the Cirrus Logic WM8524CGEDT I2S Stereo Audio DAC. 24-bit, 106dB SNR. Dual RCA line-level outputs, which are also available on the pin header.
BTW, this DAC runs directly on a single 3v3 supply. It has a built-in charge pump and bias servo to output true 2V line-level signals without using external coupling capacitors. This also eliminates the "pops" commonly encountered when these devices are powered on or off. Cool! :)
Eagle 7.5 files for this audio DAC board are available in the project files section.
PCB on OSH Park
oshpark wrote 03/10/2017 at 17:16 • point
Awesome!  thanks for sharing
