8-Channel PLL Clock Generator
A project log for Anacon-xC
Analog video console based on XMOS xCore with VGA/NTSC/PAL video output and PS/2 mouse/keyboard input. 32-bit scanline-based rendering.
kevin-h-pattersonKevin H. Patterson • 03/09/2017 at 07:26•0 Comments
Almost done designing an 8-channel clock generator based on Silicon Labs Si5351A-B-GM. This board will be in a wide DIP form that can plug into a solderless breadboard. Control is via I2C, and up to 8 independently programmable frequencies from 8 kHz to 160 MHz can be generated. (PLL is driven by an on-board crystal.)
