I tested it using my XCORE-200 explorerKIT and the lib_i2s 2.3.0 library in "i2s_frame_master" mode. Currently I'm running it using the following parameters:
- Master Clock: 12.288 MHz (generated externally by Si5351)
- Word Clock: 48000 Hz
- mclk_bclk_ratio: 4
- mode: I2S_MODE_I2S
Right now I'm just generating some nice sine waves at different frequencies, but the output looks (and sounds) very clean. Stereo separation is tested good as well.
Kevin H. Patterson
