I recently thought about making tiny boards using ATTiny AVRs. After looking around and finding the largest one, 8k, I played around a bit with the code and found that while I could get it shrunk down to 8k, I couldnt do anything else. Unless it took a simple analog read value, there was nowhere near enough space left over for any sensors.
Justin
