RetrocadeArtwork.pdfI printed this at 60cm x 60cm.Adobe Portable Document Format - 3.88 MB - 04/20/2017 at 15:58 |
body_-_front_left.stlBody - Front leftStandard Tesselated Geometry - 126.84 kB - 04/04/2017 at 02:18 |
body_-_front_right.stlBody - Front RightStandard Tesselated Geometry - 129.87 kB - 04/04/2017 at 02:18 |
body_-_front_panel.stlBody - Front PanelStandard Tesselated Geometry - 116.68 kB - 04/04/2017 at 02:18 |
coin_slot.stlFront Panel - Coin SlotStandard Tesselated Geometry - 530.75 kB - 04/04/2017 at 02:18 |
body_-_controller_panel.stlBody - Controller PanelStandard Tesselated Geometry - 455.26 kB - 04/04/2017 at 02:18 |
controller_-_extra_support x2.stlBody - Controller Extra Supports - Print 2Standard Tesselated Geometry - 2.23 kB - 04/04/2017 at 02:18 |
body_-_back_left.stlBody - Back LeftStandard Tesselated Geometry - 82.21 kB - 04/04/2017 at 02:18 |
body_-_back_right.stlBody - Back RightStandard Tesselated Geometry - 82.60 kB - 04/04/2017 at 02:18 |
body_-_top_left.stlBody - Top LeftStandard Tesselated Geometry - 87.58 kB - 04/04/2017 at 02:18 |
body_-_top_right.stlBody - Top RightStandard Tesselated Geometry - 88.75 kB - 04/04/2017 at 02:18 |
body_-_top_tip x2.stlBody - Top Tip - Print 2Standard Tesselated Geometry - 7.50 kB - 04/04/2017 at 02:18 |
display_-_screen_panel.stlDisplay - Screen PanelStandard Tesselated Geometry - 68.25 kB - 04/04/2017 at 02:18 |
display_-_under_display_fix.stlDisplay - Under Screen Panel FixStandard Tesselated Geometry - 3.60 kB - 04/04/2017 at 02:18 |
display_-_screen_back.stlDisplay - Screen BackStandard Tesselated Geometry - 20.59 kB - 04/04/2017 at 02:18 |
display_-_screen_lock.stlDisplay - Screen LockStandard Tesselated Geometry - 22.74 kB - 04/04/2017 at 02:18 |
display_-_driver_board_standoffs.stlDisplay - Driver Board StandoffsStandard Tesselated Geometry - 32.89 kB - 04/04/2017 at 02:18 |
marquee_-_bottom.stlMarquee - BottomStandard Tesselated Geometry - 420.59 kB - 04/04/2017 at 02:18 |
marquee_-_led_panel_clip.stlMarquee - LED Panel ClipStandard Tesselated Geometry - 2.82 kB - 04/04/2017 at 02:18 |
marquee_-_top.stlMarquee - TopStandard Tesselated Geometry - 294.42 kB - 04/04/2017 at 02:18 |
raspberry_pi_standoffs.stlRaspberry Pi StandoffsStandard Tesselated Geometry - 33.68 kB - 04/04/2017 at 02:18 |
back_panel.stlBack PanelStandard Tesselated Geometry - 378.79 kB - 04/04/2017 at 02:18 |
back_panel_-_handle.stlBack Panel - HandleStandard Tesselated Geometry - 58.48 kB - 04/04/2017 at 02:18 |
back_panel_-_powervolume.stlBack Panel - Power + VolumeStandard Tesselated Geometry - 105.26 kB - 04/04/2017 at 02:18 |
back_panel_-_usb.stlBack Panel - USBStandard Tesselated Geometry - 31.43 kB - 04/04/2017 at 02:18 |
back_panel_-_lock_key.stlBack Panel - Lock KeysStandard Tesselated Geometry - 173.52 kB - 04/04/2017 at 02:18 |
