Pressure Sensor Breakout Board
A project log for Space Whistle - wind controller - musical IoT
A highly responsive wind controller with expressive continuous push buttons based on linear hall-effect sensors - A musical IoT device -
ventosusventosus 07/29/2014 at 18:030 Comments
We have designed a simple break out board for the MP3V5010DP pressure sensor which comes with its own low drop out voltage regulator (MCP1703) so you can power it with e.g. 5V instead of the needed 3.3V. Additionally there is an OpAmp (MCP601) on board to add some arbitrary offset (0-3.3V) and gain(1-2x) to the sensors analog output via two trim potentiometers. All the components are SMD, which makes the board dimensions rather small (20x40mm), ideal to fit into nice casing.
The sources can be found at: https://github.com/OpenMusicKontrollers/space_whistle_pressure
Here the schematic from KiCAD:
Here the renders from OSHPark:
