I've started laying out the back plane -
I am having some issues. The backplane is bigger than a A4 sheet of paper so I have been cutting the width of it back. It is still printing out of proportion and I don't know why. What should be 11 inches is coming out as 10.9 inches on paper.
After this issue occurred I went and checked my etching bowl and it's too small as well :(
The connectors arrived, 5 of each. Enough to get started.
The layout is like this -
Power
8 signals
GND
8 signals
Power
8 signals
GND
8 Signals
Power
8 signals
GND
8 Signals
Power
8 signals
GND
MOAR POWA !!!
I'd use more ground and power traces but it's hard because you use only 64 of the 96 pins.
Seriously, if you can etch that by hand, you're a genius. I'd rather chase a used backplane on eBay...
