• The box is built.
    Justin Cole • 03/06/2017 at 15:42 • 0 comments
    Over the weekend I was able to finish the box up. I got the lid panels cut and attached with the window installed. I cut out the holes and installed the kill switch, exhaust fan, and power input. I also picked up a 24" x 24" piece of aluminum to use as the bed so hopefully no fires will be started.
    This week I hope to finish the wiring and start testing.
