TEAC-FD235HF-A291--booleans.pdf
Floppy drive manual... this drive is *not* from the Omni4, but this manual has extensive data regarding the boolean-logic implemented in drives' circuitry regarding I/O. E.g. /STEP is ignored if /WG is active.
Adobe Portable Document Format - 481.84 kB - 11/15/2017 at 11:37
Preview
Download
photos2 0_TheseArePriorToWhitePowder_MaybeChipMarkingsReadableHereEh_TODO.zip
Old photos of the Logic Analyzer PCB prior to the "white-powder" incident, which destroyed readability of many chips. It's plausible some of the now unreadable chip-markings may be readable in some of these images (plausibly with some image-processing: contrast-adjustment, etc.).
Zip Archive - 32.04 MB - 10/08/2017 at 05:07
Download
OMNI4-fullsystem-20170926d.lst
Combined disassembly of boot ROM and all operating system components. This is ongoing work, current as of the timestamp in the filename.
(Note from esot.eric: WTF!!!! This is some INCREDIBLE work, here, by ziggurat29!)
lst - 639.21 kB - 09/27/2017 at 03:20
Download
others 0.zip
some other files from the logic-analyzer disk that may be part of the LA program, including la.la0 (?), la1.lah and la2.lah (which appear to be help files), z80.z80 (which appears to be an example for disassembling with the logic analyzer), pg.com (pattern-generator), prog.com (PROM programmer). These files were not verified with the originals and transferred at 300BPS, so I don't plan to verify them any time soon.
IMPORTANT NOTE!!! These files were serially-transferred via PIP.COM, which appears to have converted "Tab" to spaces, regardless of whether the files were transferred as binaries. These are PROBABLY WRONG. Instead, try using cpmtools with the 'kpiv' format (despite its being a KayPro 2x, not an IV/4) on the raw binary disk-image.
Zip Archive - 72.71 kB - 09/17/2017 at 23:51
Download
la.com.6.bs=1
la.com, copied from the original floppy via serial port at a whopping 300BPS.
Several other files exist which may be necessary for running this program (e.g. la1.lah)... These are large and not (yet?) downloaded.
bs=1 - 33.54 kB - 09/17/2017 at 19:02
Download
OMNI4U9.txt
Character Generator rendered into glourious ASCII art for the human eye's delight.
plain - 54.12 kB - 09/15/2017 at 16:05
Download
OMNI4U34.HEX
U34 on the KayPro motherboard... This appears to be the boot-ROM/BIOS, and contains messages specific to the OMNI4. 2764 eprom
This was read by physically removing the EPROM and plugging it into a chip-programmer.
This file also appears to exist on the floppy disk-image as "K2XBOOT"
hex - 22.51 kB - 09/13/2017 at 07:23
Download
OMNI4U9.HEX
U9 on the KayPro motherboard... apparently "K2xCHAR" the character-generator ROM 2732 eprom
This file also appears to exist on the floppy disk-image as "K2XCHAR"
hex - 11.26 kB - 09/13/2017 at 07:23
Download
8716101504835110184.pdf
CP/M 2 manual. Thanks again ziggurat29!
Adobe Portable Document Format - 528.06 kB - 09/10/2017 at 20:12
Preview
Download
5620701505058721359.pdf
KayPro Service manual. We thinks this is a KayPro 2x. Thanks ziggurat29!)
(Update: There appear to be later revisions of this manual online, but they don't seem to contain any additional information, e.g. where the document says ~ "Updates coming soon".)
Adobe Portable Document Format - 6.20 MB - 09/10/2017 at 19:57
Preview
Download
OMNI4FIN.IMD
Omni 4 disk image, FINALLY!
Use ImageDisk from: www.dunfield.com
If you use cpmtools with it, specify the 'kpiv' format.
(WTF. Did I really figure that out when I uploaded this long ago?!)
And PLEASE contact me if you use this... OMNI4 users/owners seem sparse, to say the least! We should be in-conact! eric waz hung at gmail dot com
- 353.86 kB - 03/29/2017 at 07:42
Download
