Further Battery Fun
A project log for GameBoy Zero, but smaller!!
My attempt to get the smallest, simplest GameBoy style device, based on the pi Zero
mooseprmoosepr 04/06/2017 at 10:557 Comments
So i thought, 'hmm alkaline cells are like 2000mah, maybe i could use them here....'
well the first problem is the voltage. 2xAA cells give you 3v, the pi can run as low as 2.7v, so we could use that!!
So i wired it up, and it worked... for all of 15 minutes... it seems that alkaline batteries drop voltage very fast. we need to boost that voltage!!
So i raided the parts bin, and i found an adjustable buck/boost board, gave that a go
didnt even make the start!! seems the boost board wont work below 3v
so plan C, over to pololu and one of there boost boards boosty which can take an input as low a 0.5v and boost it up so we looked like we were onto a winner
So testing began, and i was expecting big things, 2000mah should technically yield 8 hours, but after just 3 hours, the pi started rebooting. seems that boosing the voltage isnt as simple as it seems!! to get 3.3v @ 200ma on the output, the input needs more current. so as the voltage drops, the current requirements raise.
vin current (ma)
3 220
2.75 240
2.5 264
2.25 293
2 330
1.75 377
1.5 440
1.25 528
1 660
0.75 880
0.5 1320
so as we can see here, things will quickly snowball. as the voltage drops, the current raises, which will force the voltage lower, and the current higher, and so on, until the batteries just give up.
So using lithium batteries is a much better prospect, as the voltage in general is higher, and there is no need for boosting!
K.C. Lee wrote 04/06/2017 at 14:55 point
The problem with AA cell is that the internal resistance is relatively high, so you'll get a lot of droop and energy lost internally.  It simply isn't designed for high current loads.  NiMH AA cell on the other hand would do a bit better.
e.g. My old digital camera can take 2-3 pictures with new alkaline AA and die.  With AA NiMH, it can take 80 or so and some with flash.
Common LiPo battery is 3.7V to 4.2V.  LiFePO4 on the other hand is 3V to 3.6V which can be used without regulator.  (see the LiFe Pi project)
moosepr wrote 04/06/2017 at 15:22 point
yeah i am using unboosted generic li-po cells normally, can get 4-5 hours from a 1000mah cell.
i didnt want to try NiMH batteries because i know they dont like being sucked totally dry. I guess 3 cells unboosted would be the ideal, but then there is no space advantage over the li-po really
K.C. Lee wrote 04/06/2017 at 15:55 point
Regular AA has the advantage of easy to find in a store in a pinch when your batteries are running low. NiMH isn't and not usually come fully charge.  Hope you LiPo cells are of the protected variety as they don't like over discharged.
moosepr wrote 04/06/2017 at 16:21 point
seems it wont let me reply to your new comment :P
im using the TP4056 protection boards http://www.hotmcu.com/tp4056-micro-usb-5v-1a-lithium-battery-charger-with-protection-p-176.html
they seem to have the protection cut off a little low (2.4v) but the pi will start behaving weird at 2.7v so you will never really get too low
K.C. Lee wrote 04/06/2017 at 17:00 point
There is a limit on the levels of nested replies.
In general Li battery doesn't like to be deeply discharged as the cycling takes away battery lifetime. 3V is commonly used as the lowest point.  May be some sort of low battery warning or battery level indicator is needed.
moosepr wrote 04/06/2017 at 17:51 point
ah that makes sense! I did plan on adding an attiny to so some safe shutdown/power metering kinda stuff. I had assumed the protection board stepped in sooner, but hey!
Marq Watkin wrote 04/06/2017 at 13:02 point
Thanks for sharing your experiments with power sources, it's great to read
