lil bit of polish
A project log for GameBoy Zero, but smaller!!
My attempt to get the smallest, simplest GameBoy style device, based on the pi Zero
mooseprmoosepr 03/04/2017 at 21:332 Comments
So the original board works, but its not quite usable. The switch actually disconnects the power from the protection board, so tuning it off actually triggers the protection, and you need to plug the charger in to get it to reset.
also this means that it has to be on to charge!!
So i have fixed that, made holes in all 4 corners so its easier to mount in a case.
if anyone wants to play with the board i have stuck it on OSHpark
https://oshpark.com/shared_projects/sYgn53n6
davedarko wrote 03/04/2017 at 22:38 point
the link gets removed in the normal editor, you have to add the embed stuff in html editing mode. That's the <> button on the left.
moosepr wrote 03/04/2017 at 23:26 point
ah good catch man!! i will fix that, thanks!
