The WaFilTer is going to be composed of two main parts. Each of the two parts are going to be contain in a 5 liter bucket.
The first part is going to be for the different types of filters. Those following elements are the different filters: a carbon filter, fine sand, filter cartridges, pool filter (which will be between the two parts).
The second part is going to be for the UV lamp the LED.
After all we are going to press over the first part to force the water to flow down.
The clean water is going to drop from the bottom of the second bucket into a glass.
Then we will just have to drink it and taste it... :)
WaFilTer
Uncle Toby and Aquaman
Anteneh Gashaw
