Deltagear.stlThis gear has to be printed 3 times. It fits exactly over one of the standard horns. Please cut of exess of the horns!- 37.00 bytes - 03/05/2017 at 15:04 |
Deltatriangle top1.stlThis part to be printed once; it is the top of the unit.- 55.00 bytes - 03/05/2017 at 15:04 |
deltabeam.stlThis part to be printed 3 times. It may be necessary to sand in order to fit smoothly in the Deltatriangle parts.- 37.00 bytes - 03/05/2017 at 15:04 |
Deltatriangle bottom1.stlThis part to be printed once. It is the bottom part of the unit. The wires coming from the servo's should be put through the holes.- 61.00 bytes - 03/05/2017 at 15:04 |
newdeltatop1.stlThis part to be printed once.- 43.00 bytes - 03/05/2017 at 15:04 |
