The UV curing liquid
A project log for CNC Add-on: Rot. Laser Soldering Paste applicator
Using a cheap tire compressor, driven by a stepper motor, to apply solder paste from a syringe and then soldering small wires to components.
AltMarcxsAltMarcxs 09/29/2014 at 03:590 Comments
Good news it's seems that the 445nm laser can also cure this, but  using only 2x 385nm LED isn't enough, the 415nm laser is much faster, have to make a heat sink for the last.
Keep bottle upright.
