More pictures
A project log for CNC Add-on: Rot. Laser Soldering Paste applicator
Using a cheap tire compressor, driven by a stepper motor, to apply solder paste from a syringe and then soldering small wires to components.
AltMarcxsAltMarcxs 07/25/2014 at 16:400 Comments
Blue, Green, Red Laser on
These are only for better view, blue and green crosses and red vertical (will be the UV-laser.
