RFC2324/7168: HTCPCP
A project log for HTTaP
Test Access Port over HTTP
yann-guidon-ygdesYann Guidon / YGDES • 04/26/2020 at 22:03•0 Comments
Replying to Thomas P. :
No, HTTaP is not directly compatible with HTCPCP  or its extensions because they work at a lower level. HTTaP works at a higher level, above the server level, using the HTTP protocol to transmit the data as payload instead of in the headers and meta-information.
Thomas is free to implement similar functionalities using the HTTaP features and protocol for the next April, 1st ;-)
