Loopback server
A project log for HTTaP
Test Access Port over HTTP
Yann Guidon / YGDESYann Guidon / YGDES 03/28/2017 at 00:180 Comments
HTTaP is meant to help integrate #YGWM with a web-based system, and there is more to it than serving files or sending commands to TCP widgets.
Any editor needs to read and write files from the local disk/storage and the chosen language/framework (HTML/JS) does not allow that. The web browser prevents scripts from doing it, for obvious security reasons !
Yet there is a solution. Or more precisely, it's a hack ! I have described it in an article in French:
"Accéder aux fichiers en JavaScript (ou le Cross-Site Scripting utile)" in GLMF#105 pp.42-54
This describes a dirty trick, using a PHP script along with a specially crafted HTML/JS page :
Note : these manipulations usually require user interaction and are not inherently more unsafe than usual methods.
The PHP script was a pain to write and I'm glad to have a totally controlled environment (the HTTaP server) where I can process the data without layers of gotchas and poisonous sugaring...
The JS framework has evolved too and "binary blobs" now solve many of the encoding problems I have !
The "Loopback" feature should be a standard, user-configurable, option in the HTTaP protocol, with its own access key.
Now, it seems that interactive websites use a technique similar to the loopback server. An example is the circuit simulator at
I recently spotted an addition to the HTML5 standard at which looks promising but it doesn't seem to writte files, and support is yet untested and unknown. I hope that my system works with HTML4 clients.
