HTTaP root object
A project log for HTTaP
Test Access Port over HTTP
yann-guidon-ygdesYann Guidon / YGDES 03/31/2017 at 09:290 Comments
The first thing that a HTTaP client does, upon first connection to a server, is to check its configuration and characteristics. They are provided by a JSON object with these properties:
More will appear as the protocol grows...
As of 20200511 the current implementation returns this root object :
 "HTTaP_open": 1,
 "HTTaP_version":"20200511",
 "ID":"blocking server with HTTaP",
 "Services":"Files "
 More will probably follow.
