Key Features
- Power over Ethernet (PoE): Enables streamlined installation with both power and network connectivity through a single cable.
- 42 Optoisolated Zones/Inputs: Provides reliable and robust monitoring for contacts, sensors, and other digital I/O devices.
- 3 Relay Outputs: Designed for controlling 12V devices, such as sirens, strobes, or other auxiliary equipment.
- Pre-Flashed wESP32 Module: Includes ESPHome firmware for immediate out-of-the-box compatibility with smart home systems.
- Thermal Management: Integrated thermal heat sink ensures efficient cooling of the wESP32 module during operation.
- Flexible Power Options: Operates seamlessly with PoE or an external 12V power supply, offering versatility in installation environments.
- 3-12V DC Trigger Input: Compatible with a wide range of triggering devices.
- Integrated Digital I/O Circuitry: Supports enhanced sensing for smart automation and security applications.
Specifications
- Dimensions: 262mm x 188mm.
- Open-Source Licensing: Licensed under the GNU General Public License and the MIT License, ensuring accessibility and transparency.
- Platform Support: Fully compatible with Home Assistant and ESPHome for seamless integration into smart home ecosystems.
- User-Centric Design: Provides easy customization and supports a variety of applications including environmental monitoring, access control, and smart automation.
Licensing
- Open-source hardware and software design, licensed under GNU GPL and MIT licenses.
Christopher Greenlee
Makerfabs
ssla-couk
Murat Doğançay
