WALKPi PCB Version
Audio Player Project Powered by Pico 2 and DF Mini Player
Greetings everyone and welcome back, This is the WalkPi, a homebrew audio player that plays music from an SD card. It is made out of a Raspberry Pi Pico 2 and a DF Mini Player. Remember the Walkman? The phrase "walkpi" is a pun. The WalkPi gets its name from the fact that it is just a walkman that is powered by a Raspberry Pi and is a little less sophisticated. This project is a follow-up to the walkpi project I created earlier using a breadboard. We added an SSD1306 OLED display and a few buttons that allow the user to use the WalkPi. The buttons let the user choose songs from the menu on the OLED screen, adjust the volume, choose a song, and switch the device on or off.
Breadboard Setup
We already designed the WalkPi's Basic Breadboard configuration.
The star of this project is the DFPlayer Mini, which is a mini MP3 Player Module that is based around a 24-bit DAC IC along with an onboard SD Card reader that fully supports the FAT16 and FAT32 file systems.
The project's brain, the Raspberry Pi Pico, is connected to the DF Mini Player, a small, low-cost MP3 module with a simple output straight to the speaker.
We included the SSD1306 OLED screen to show the song list, volume settings, and other information in addition to song names.
Here's the brief article about how we setup the breadboard setup:
https://www.hackster.io/Arnov_Sharma_makes/walkpi-breadboard-version-317c16
In order to simplify the design process for subsequent iterations, we evaluated all of the device's internal workings in the breadboard version, which was the first step of testing this project before proceeding to the PCB design phase.
PCB Design
The project's PCB design begins with the creation of a schematic, which is separated into seven circuit parts: the Raspberry Pi Pico 2, the WS2812B LED array, the RIGHT Angle Switch Array, the OLED screen, the DFPLAYER, the Audio Jack-Speaker Switch, and the Power Managamenet Setup.
The IP5306 Power Management Board Setup is the first thing we will go over. Its basic configuration includes the IP5306 IC itself, along with decoupling capacitors on the input, output, and battery sides, LEDs for the battery fuel level, a Type C port for input that will be used to charge the cell, and an SMD inductor that will increase the 3.7V cell's output to a constant 5V.
Next comes the Pico 2 Setup, which connects to the OLED display's I2C ports as well as the DF Mini Player's TX and RX pins. To function, the DF Player, the OLED screen, and the PICO's VCC require 5V from the power management board setup.
We added an interesting feature to this device: the DF Mini player's output is connected to the central terminal of a Slide DPDT Slide switch, which is also connected to an audio jack and speaker. The sliding switch allows the user to play music via either the audio jack or the speaker.
An array of WS2812B LEDs was also added; four of the LEDs were connected in their standard configuration, with the first LED's Din connected to PICO's GPIO0. The first LED's dout is connected to the second's din, the second's dout is connected to the third's din, and so on, up to the fourth LED.
Finally, we employed a total of six buttons in this project, five of which are connected to PICO and will be used for up-and-down navigation, music selection, and volume up-and-down control. In order to turn the device on and off, the sixth button is connected to the power management setup.
Following the creation of the schematic, we also created a mockup CAD file for the board, in which we modeled every component that we would need to install in the circuit, including the PCB, vertical push buttons, Raspberry Pi Pico, DF Mini Player, slide switch, and Type C port.
We create the board layout and arrange all the parts to complete the circle using the dimensions obtained from the Cad file.
PCBWAY Service
Following the completion of the board design, we ordered PCBs in white solder masks with black silkscreen and submitted the PCB's Gerber data on the PCBWAY quote page.
PCBs were received within a week, and the PCB quality was outstanding. Here, we added a few design elements on the board's silkscreen layer to increase the aesthetic appeal of the project. PCBWAY made the custom layer properly, which shows their great PCB manufacturing capabilities.
Also, PCBWay is hosting its 7th Project Design Contest, a global competition that invites electronics enthusiasts, engineers, and makers to showcase their innovative projects. The contest provides a platform for participants to share their creativity and technical expertise with the broader community.
... Read more »
Aud Player v14.f3d
fusion - 3.81 MB - 11/27/2024 at 10:50
Download
SCH.pdf
Adobe Portable Document Format - 208.73 kB - 11/27/2024 at 10:50
Preview
  • 1
    PCB Assembly Process
    • Applying solder paste to each component pad is the initial step in the circuit-building procedure. In this case, a solder paste dispenser synringe with 63/37 Sn/Pb solder paste is used.
    • Next, we pick and place each component in its proper place.
    • After that, we lift the circuit and place it on the reflow hotplate, which increases the PCB's temperature to the point where solder paste melts and all SMD components attach to their pads.
    • Then, using a soldering iron, we solder all of the component leads in their proper locations after placing all of the through-hole components, such as the horizontal push buttons, Type C port, and CON2 JST connectors.
  • 2
    Adding Modules onto the Circuit (OLED, PICO, DF Player)
    • We now set up every module, including the DF Mini Player, Pico 2, and SSD1306 Display, in its proper location. The SSD1306 Display is first added to the circuit from the top side, and its pad is subsequently soldered from the bottom side.
    • Using a soldering iron, the terminals of the DF Mini Player are soldered from the top side of the board to the bottom side of the circuit.
    • We also included two JST connectors, which will be used to connect the battery and speaker.
    • In its place, we finally installed the Raspbery Pi Pico 2. We soldered the Pico directly onto the circuit using its castellated pads.
    The circuit assembly is now complete.
  • 3
    CODE
    Next is the project's code, which is large but takes a very straightforward approach.
    #include <Wire.h>
    #include <Adafruit_GFX.h>
    #include <Adafruit_SSD1306.h>
    #include <SoftwareSerial.h>
    #include <DFRobotDFPlayerMini.h>
    #include <Adafruit_NeoPixel.h>
    #define SCREEN_WIDTH 128
    #define SCREEN_HEIGHT 64
    #define SSD1306_I2C_ADDRESS 0x3C
    #define LED_PIN 0
    #define NUM_LEDS 4
    Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT);
    Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
    // DFPlayer connections
    SoftwareSerial mySerial(9, 8); // RX (Pico) to TX (DFPlayer), TX (Pico) to RX (DFPlayer)
    DFRobotDFPlayerMini myDFPlayer;
    // Button pins
    const int buttonPinNext = 27; // Next song button
    const int buttonPinPrev = 26; // Previous song button
    const int buttonPinSelect = 12; // Select song button
    const int buttonPinVolumeUp = 13; // Volume up button
    const int buttonPinVolumeDown = 14; // Volume down button
    String songNames[50]; // Placeholder for song names from the SD card
    int totalSongs = 0;
    int currentSongIndex = 0; // Start with the first song
    int volume = 10; // Initial volume level (0-30)
    unsigned long lastDebounceTime = 0; // For navigation button debounce
    unsigned long debounceDelay = 250; // Debounce delay in milliseconds for navigation buttons
    bool isPlaying = false;
    // Function declarations
    void listSongsFromSD();
    void displayVolume();
    void playVisualizer();
    void displaySongInfo();
    void setLEDsRed();
    void setLEDsPurpleAndBlue();
    void setup() {
    // Initialize Serial and the display
    Serial.begin(9600);
    mySerial.begin(9600);
    display.begin(SSD1306_SWITCHCAPVCC, SSD1306_I2C_ADDRESS);
    display.clearDisplay();
    // Initialize DFPlayer
    display.setTextSize(1);
    display.setTextColor(SSD1306_WHITE);
    display.setCursor(0, 0);
    display.println("Init DFPlayer...");
    display.display();
    delay(1000); // Pause for observation
    if (!myDFPlayer.begin(mySerial)) {
    display.setCursor(0, 10);
    display.println("DFPlayer Init Failed!");
    display.display();
    while (true); // Halt further execution
    myDFPlayer.volume(10);  // Set initial volume
    display.setCursor(0, 20);
    display.println("DFPlayer Initialized");
    display.display();
    // Set up button pins
    pinMode(buttonPinNext, INPUT_PULLUP);
    pinMode(buttonPinPrev, INPUT_PULLUP);
    pinMode(buttonPinSelect, INPUT_PULLUP);
    pinMode(buttonPinVolumeUp, INPUT_PULLUP);
    pinMode(buttonPinVolumeDown, INPUT_PULLUP);
    // Initialize the LED strip
    strip.begin();
    strip.show(); // Initialize all pixels to 'off'
    setLEDsRed(); // Set initial state to red
    // Display welcome message
    display.setTextSize(2);
    display.drawRect(0, 0, 128, 64, SSD1306_WHITE); // Frame box
    display.setCursor(18, 25);
    display.println("Welcome!");
    display.display();
    delay(2000);
    display.display();
    // Read and display song names from SD card
    listSongsFromSD();
    void loop() {
    unsigned long currentMillis = millis();
    // Display song menu
    display.drawLine(0, 10, 128, 10, SSD1306_WHITE); // Line under the title
    display.setCursor(5, 0);
    display.print("Select Song:");
    // Display the list of songs with an arrow
    display.setCursor(5, 13 + currentSongIndex * 10);
    display.print(">");
    for (int i = 0; i < totalSongs; i++) {
    display.setCursor(15, 13 + i * 10);
    display.print(songNames[i]);
    // Display current volume
    display.setCursor(5, 55);
    display.print("Volume: ");
    display.print(volume);
    display.display();
    // Check for button presses with debounce for navigation buttons
    if ((currentMillis - lastDebounceTime) > debounceDelay) {
    if (digitalRead(buttonPinNext) == LOW) {
    currentSongIndex = (currentSongIndex + 1) % totalSongs; // Loop back to start
    lastDebounceTime = currentMillis;
    if (digitalRead(buttonPinPrev) == LOW) {
    currentSongIndex = (currentSongIndex - 1 + totalSongs) % totalSongs; // Loop to end
    if (digitalRead(buttonPinSelect) == LOW) {
    myDFPlayer.play(currentSongIndex + 1); // Play selected song
    isPlaying = true;
    playVisualizer();
    // Check for volume button presses separately with a shorter debounce delay
    if (digitalRead(buttonPinVolumeUp) == LOW) {
    if ((currentMillis - lastDebounceTime) > 50) { // Shorter debounce delay for volume buttons
    if (volume < 30) { // Max volume is 30
    volume++;
    myDFPlayer.volume(volume); // Update volume on DFPlayer
    displayVolume();
    if (digitalRead(buttonPinVolumeDown) == LOW) {
    if (volume > 0) { // Min volume is 0
    volume--;
    displayVolume();
    // Automatically play the next song if the current one ends
    if (myDFPlayer.available()) {
    if (myDFPlayer.readType() == DFPlayerPlayFinished) {
    displaySongInfo();
    // Handle LED colors based on whether a song is playing
    if (isPlaying) {
    } else {
    setLEDsRed();
    // Function to list songs from SD card (Mock implementation)
    void listSongsFromSD() {
    // Placeholder implementation to list songs
    songNames[0] = "Song 1";
    songNames[1] = "Song 2";
    songNames[2] = "Song 3";
    totalSongs = 3;
    // Function to display volume change
    void displayVolume() {
    display.setCursor(35, 10); // Adjusted position
    display.print("Volume");
    display.setCursor(55, 35); // Position below the word
    display.display();
    delay(1000); // Show volume for 1 second
    // Simple visualizer function
    void playVisualizer() {
    // Basic visualization while playing
    display.setCursor(10, 20);
    display.print("Now Playing:");
    display.setCursor(10, 40);
    display.print(songNames[currentSongIndex]);
    display.display();
    // Visualizer loop
    for (int i = 0; i < 20; i++) {
    display.fillRect(i * 6, 50, 5, random(10, 30), SSD1306_WHITE);
    display.display();
    delay(50);
    display.fillRect(i * 6, 50, 5, random(10, 30), SSD1306_BLACK);
    // Function to display current song info
    void displaySongInfo() {
    display.print("Playing:");
    display.display();
    // Functions to control the LED strip
    void setLEDsRed() {
    for (int i = 0; i < NUM_LEDS; i++) {
    strip.setPixelColor(i, strip.Color(255, 0, 0)); // Red color
    strip.show();
    void setLEDsPurpleAndBlue() {
    strip.setPixelColor(i, strip.Color(128, 0, 128)); // Purple color
    strip.show();
    delay(500);
    strip.setPixelColor(i, strip.Color(0, 0, 255)); // Blue color
    strip.show();
    delay(500);
     The constants that specify the display's dimensions and I2C address, as well as the LED pin and number of LEDs, are all included in the first section of this code, which also includes all the libraries you must right away install. Additionally, it includes objects such as the NeoPixel strip and the OLED display, respectively.
    The first section also assigns button pins, stores song names in an array called songNames, and uses certain variables to monitor the number of songs, the song index that is currently selected, and the volume level.
    The OLED display and the DF Mini player are initiated by the Section's Setup Function, which also includes a tiny part that checks to see if the DF player's initialization failed or was functioning well.
    Along with the WS2812B LED, which is configured to glow red, this function also includes buttons that configure each button as an input. We also added a welcome message that will appear each time the device starts on.
    The third section, or the Loop Function, is made up of seven parts, including the Current Time, which keeps track of time in microseconds and manages button debounding, Song Menu Structure, Song List, and volume display. The navigation button functions by detecting if buttons are being pressed and updating the song index accordingly. The volume buttons perform the same function as the song index but also control the LED and play the next song segment.
    Before using this sketch, make sure you install the libraries listed below.
    #include <Wire.h>
View all 5 instructions
