0.3.0 : Replace stcflash by stcgal -> stc15 best process, add STC15W408AS-DIP16
0.3.1 : Bugs fixed
0.3.2 : Mini bugs fixed. Primary linux beta version ready : See dependencies packages installation.
0.3.3 : Mini bugs fixed. Speed uplaod bug fixed / choice speed upload menu added
0.3.7 : Add Serial.readString / Add push-pull output configuration for STC micro-controllers
#Todo
analogRead, analogWrite etc...
#Installation and test
1/ Donwload Arduino >= V1.8.19
2/ Launch Arduino
3/ In Arduino->Preferences->Additional Board Manager URLS
add http://bacciel.com/tools/package_ardui89_index.json
4/ In Tools->Boards:...->Board Manager
search "8051"
select and install "ardui89 8051 family Boards"
5/ In Tools->Board:...
select "Board : "STC89C51" "STC89C52" "....""
6/ Demos :
Use Blink.ino in basics examples or in Ardui89_demos path :
Hello.ino
Howareyou.ino
and build and upload !
#Linux Dependencies
python3 / python3-pip / stcgal / sdcc
Under terminal :
1/ Installing stcgal :
sudo apt-get install python3 python3-pip
sudo python3 -m pip stcgal
2/ Installing SDCC :
sudo apt-get install sdcc
Many thanks
Cyril BARBATO
cyril.barbato@gmx.com
# Arduino <=> 8051/89C5x/STC32G12K128 pinout equivalent
(Ardui89 Cinque Uno/Due/128k R0)
D : Arduino digital pins
A : Arduino analog pins
LED_BULTIN : D13 (P3.5)
D D A
7 P1.0 -------| 1 P1.0 VCC 40 |------ VCC
8 P1.1 -------| 2 P1.1 P0.0 39 |------ P0.0 (AD0) 31 A7
2 P1.2 -------| 3 P1.2 P0.1 38 |------ P0.1 (AD1) 30 A6
3 P1.3 -------| 4 P1.3 P0.2 37 |------ P0.2 (AD2) 29 A5 SCL
4 P1.4 -------| 5 P1.4 P0.3 36 |------ P0.3 (AD3) 28 A4 SDA
5 P1.5 (MOSI)-| 6 P1.5 (MOSI) P0.4 35 |------ P0.4 (AD4) 27 A3
6 P1.6 (MISO)-| 7 P1.6 (MISO) P0.5 34 |------ P0.5 (AD5) 26 A2
7 P1.7 (SCK)--| 8 P1.7 (SCK) P0.6 33 |------ P0.6 (AD6) 25 A1
RST -------| 9 RST P0.7 32 |------ P0.7 (AD7) 24 A0
0 P3.0 -------| 10 P3.0 (RXD) (VPP) EA 31 |------ EA (VPP)
1 P3.1 -------| 11 P3.1 (TXD) (PRG) ALE 30 |------ ALE (PRG)
10 P3.2 -------| 12 P3.2 (INT0) /PSEN 29 |------ /PSEN
11 P3.3 -------| 13 P3.3 (INT1) P2.7 28 |------ P2.7 (A15) 23
12 P3.4 -------| 14 P3.4 (T0) P2.6 27 |------ P2.6 (A14) 22
13 P3.5 -------| 15 P3.5 (T1) P2.5 26 |------ P2.5 (A13) 21
14 P3.6 -------| 16 P3.6 (WR) P2.4 25 |------ P2.4 (A12) 20
15 P3.7 -------| 17 P3.7 (RD) P2.3 24 |------ P2.3 (A11) 19
XTAL2 -------| 18 XTAL2 P2.2 23 |------ P2.2 (A10) 18
... Read more »
Cyril BARBATO
Esmacat
