Next, the case !
A project log for Building a Mechanical Keyboard
A DIY 60% mechanical keyboard based on Cherry MX blue switches
grgory-paulGrégory Paul 03/05/2017 at 14:480 Comments
The case
The next part of the process is to design and build the case.
The case is composed of 4 plates :
  1. the « base » plate where switches will be mounted,
  2. the « supporting » plate,
  3. the « spacer » plate,
  4. the bottom plate.
In picture :
        _
     __|_|__
|                | 1.5mm « base » plate
|   \_______/    | 5mm « supporting » plate
|     |   |      | 5mm « spacer » plate
|                | 5mm « bottom » plate
The goal is to design 4 SVG files that will feed a laser cutter.
Since I’m not familiar at all with that process, I'm thinking to first design a 3 keys keyboard (volume up, down and mute).
That will limit the costs if things goes wrong.
