ColecoOnOffTop.stl
Glue together with ColecoOnOffBottom for a power switch actuator
Standard Tesselated Geometry -
307.50 kB -
02/06/2025 at 09:53
Download
ColecoOnOffBottom.stl
Glue together with ColecoOnOffTop for a power switch actuator
174.59 kB -
02/06/2025 at 09:53
Download
ColecoResetTop.stl
Glue together with ColecoResetBottom for a reset switch actuator
260.24 kB -
02/06/2025 at 09:52
Download
ColecoResetBottom.stl
Glue together with ColecoResetTop for a reset switch actuator
151.16 kB -
02/06/2025 at 09:52
Download
ColecoPowerSwitchCap.stl
Small cap to put on the MFP201 switch to make it work with the stock CV power switch actuator
11.41 kB -
02/06/2025 at 09:51
Download
ColecoDinCoverPAL.stl
Bezel for use with PAL CV enclosure with hole for MiniDIN jack
1.64 kB -
02/06/2025 at 09:49
Download
ColecoResetWasher.stl
Small washer to install on non-Coleco reset switch to make it work with the CV reset actuator
65.90 kB -
02/06/2025 at 09:46
Download
ColecoPowerPlate.stl
Small plate to replace the original CV power jack featuring a hole for a standard barrel jack
21.57 kB -
02/06/2025 at 09:44
Download
