A QEMU-based emulation environment for the Espressif ESP32 board on Docker
$ docker run -it -p 8080:80 mluis/qemu-esp32
$ idf $ idf.py build -C program $ ./flash.sh program/build/emulation.bin $ qemu-system-xtensa -nographic -M esp32 -m 4 -drive file=flash.bin,if=mtd,format=raw -nic user,model=open_eth,hostfwd=tcp::80-:80
http://localhost:8080/hello
$ docker build . -t qemu-esp32$ docker run --name qemu-esp32 --rm -i -p 8080:80 -t qemu-esp32 bash$ idf
View all 5 instructions
That's Best.
You can also check my Project. Here is link: https://menuprices.my/bob-burger-menu/
Pratik Mokashi
Noritama
MongooseOS
Paco Alacreu
Yes, delete it Cancel
You are about to report the project "QEMU-ESP32", please tell us the reason.
That's Best.
