#Instructions modified from https://github.com/csimmonds/a4b-scripts/blob/master/build-beagleboneblack.sh
cd ~/android-AOSP/device
mkdir ti
cd ti
git clone https://github.com/csimmonds/a4b-beagleboneblack
cd a4b*
git checkout m6.0
cd ..
mkdir beagleboneblack
mv -v ~/android-AOSP/device/a4b-beagleboneblack/* ~/android-AOSP/device/ti/beagleboneblack/
rm -rf a4b-beagleboneblack
THIS IS STILL MUDDY WATER. There needs to be a different patch file because I modified some of the files. WARNING: Don't follow the instructions here.
cd ~/BBB
mkdir u-boot_stock
mv -v u-boot/* u-boot_stock/
rm -rf u-boot
git clone https://github.com/csimmonds/u-boot.git
cd u-boot
git checkout am335x-v2013.01.01-bbb-fb
cd ..
mkdir u-boot_droid
mv -v u-boot/* u-boot_droid/
rm -rf u-boot
git clone https://github.com/beagleboard/bb.org-overlays.git
git clone https://github.com/csimmonds/a4b-scripts.git
cd a4b*
git checkout m6.0
cd ..
cd bb-kernel
mkdir patches/a4b
cp ~/android-AOSP/device/ti/beagleboneblack/ti-kernel-patches/config-android-4.1 patches/defconfig
cp ~/android-AOSP/device/ti/beagleboneblack/ti-kernel-patches/*.patch patches/a4b
patch -p1 < patches/a4b/0001-Add-a4b-patch.patch
Output:
patching file patch.sh
Hunk #1 succeeded at 1174 with fuzz 2 (offset 223 lines).
Hunk #2 FAILED at 988.
1 out of 2 hunks FAILED -- saving rejects to file patch.sh.rej
Solution:
add `a4b` to line# 1218 of patch.sh, and save file
comment out selinux patches in patch.sh (just not putting them into patch.sh would be better. come back to this.)
NOTE:
When I did this a second time, re-pulling the kernel to get a fresh start it I had the same problem, but with a different error message, the solution was roughly the same regardless. Also, the second time I downloaded the kernel I got 4.4.53 instead of 4.4.52
Also, as I stated in the I disabled all touchscreen inuput, and DVB front end modules and built-ins. I was getting compiler errors, so I shut it all off. The kernel built, but I'll have to see if it works.
./build_kernel.sh
cd KERNEL
cat arch/arm/boot/zImage arch/arm/boot/dts/am335x-boneblack-emmc-overlay.dtb > zImage-dtb
mkdir ~/android-AOSP/device/ti/beagleboneblack-kernel
cp zImage-dtb ~/android-AOSP/device/ti/beagleboneblack-kernel
*** I am not really sure about this step, because later when I move files
to the sd card for android I create a different image.
mkdir ~/android-AOSP/device/ti/beagleboneblack/modules
MODULES=`find -name "*.ko"`
for f in $MODULES; do
cp $f ~/android-AOSP/device/ti/beagleboneblack/modules/`basename $f`
done
cd ../../bb.org-overlays
make DTC=../bb-kernel/KERNEL/scripts/dtc/dtc
cp src/arm/*.dtbo ~/android-AOSP/device/ti/beagleboneblack/dtbo
cd ../u-boot_droid
. ../bb-kernel/.CC
Yeah, u-boot is a mess too. I'm not sure how this is going to work out.
cd ~/android-AOSP
make -j8
Now, time to get some beer. I'm done for the night.
