RotoPD - USB-C PD 3.1 Breakout I2C
Advance Power Delivery trigger that is designed up to 30V. All the power that you have ever need from USB-C! Also AP33772S Evaluation Board.
Starting from
$17.30
CentyLab has 843 orders / 14reviews
Ships from United States of America
Adding higher voltage with high power to your project has never been easier. Do you want 5A at 5A or 30V at 5A? RotoPD can negotiate all voltage in all protocol that you have ever want. It also serve at an AP33772S evaluation board with on board 5V@2A buck, QWIIC/STEMMA QT compatible.
Purchase from Tindie (USA) and Lectronz (Europe)
Status: We now can ship directly from the US.
Project Status
We got the board working on ESP32 and STM32 via Arduino Lib. We will soon release PicoSDK for RP2040 if you would like to work natively on C++.
Featured in GreatScott!
Libraries
Description
While traditional power adapters can provide a variety of current but fixed to 5V output, our RotoPD leverages advanced power delivery protocols to achieve a versatile output range— 3.5V to 30V at 150W max. The breakout board use a stand alone Power Delivery Sink controller to negotiate with your modern charger and provide different output voltage.
Centylab's RotoPD can unlock more advance mode in your USB-C power supplies like Programmable Power Supply (PPS) and Adjustable Voltage Supply (AVS), to provide even more granular voltage adjustment. The RotoPD simplifies power negotiation with USB-C adapters, handling the complex process of establishing power delivery contracts. The controller does all the heavy lifting of power negotiation and provides an easy way to configure over I2C, free your micro-controller from the complicated USB-C PD protocol.
To config the board, you will need an I2C bus. The board integrates seamlessly into the Qwiic and STEMMA QT ecosystems, no soldering is required. We also include an logic level shifter on board to work with 3.3V or 5V I2C system.
To make it even easier to use, RotoPD includes a built-in buck converter that efficiently steps down USB-C VBUS power to a stable 5V 2A output, making it perfect for powering microcontrollers, sensors, and other low-voltage components in your project.
Technical specification
  • Built-in chip: AP33772S
  • Operating voltages: from 3.3 to 30V
  • Maximum current: 5 A
  • Maximum power: 150W (30 V at 5 A)
  • Configuration: via I2C
  • Connectors: USB Type-C, headers, Qwiic, STEMMA QT
  • Weight: 4 g
Features
  • Input and output voltage range of 3.5-30V at 5A max
  • On board buck for 5V output at 2A max
  • Support Qwiic or STEMMA QT in both 3.3V and 5V I2C
  • Support PD3.1 EPR/AVS Up to 30V and SPR/PPS Up to 21V
  • Certified USB PD3.1 v1.6  TID: 10062
  • Integrated ESD and flyback diode protection
  • Integrated VBUS voltage monitoring
  • Integrated NTC temperature monitoring
  • Integrated VBUS switch gate drivers (back-to-back NMOS)
  • Support LED Indication for Different Negotiation Results
EPR/AVS Power Supplies
As the technology is getting more adoption, as Dec 2024, here are some charger/power bank reported to provide AVS voltage adjustment.
Framework 180W
AMEGAT Powerbank 140W (No longer recommend)
Baseus Powerbank 140W
UGREEN Nexode 300W
Demo
AVSFixed example with Sparkfun Pro Micro ESP32-C3. We are requesting AVS 28V.
diagram.svg
Pinout
svg+xml - 396.54 kB - 12/14/2024 at 08:40
Preview
RotoPD Schematic.pdf
Schematic
Adobe Portable Document Format - 45.01 kB - 12/14/2024 at 08:37
Preview
  • Can we program waveform? Pt1
    CentyLab08/13/2025 at 06:15 0 comments
    Just playing around to see how much we can push the AP33227S to generate a waveform. Here is some rough triangle wave. We just request voltage up and down in PPS mode.
    Next step: Find out if there is any collation between voltage request distance vs time to complete.
View project log
John Hind wrote 05/26/2025 at 15:24 point
Puzzled by how this works with PD voltages below 5V given the input to the buck converter will have to be above 5V to give 5V output? Will the '5V' output just follow the input in the range 3.5V - 5V, or will it cut out altogether? I've not yet wired the I2C to mine, but the 5V output does seem fine at the 5V vbus default (4.9V on '5V out' versus 5.0V on '+' output.
CentyLab wrote 05/27/2025 at 06:53 point
Hi John, the 5V output will follow the VBUS voltage with some reduction in head room. This is when the duty cycle of the buck is working around 98% (so around +2% voltage drop). The 3.5V is the cut off for the buck and the 5V rail will collapse altogether.
Eric Tsai wrote 03/27/2025 at 02:56 point
Great project!  Trigger boards seem like a dime a dozen, but having a programmable PSU via I2C and just providing a PPS capable USB charger - that's super useful and new.
If I need a quite a few of these on the same micro, is it possible to set the I2C address on these separately?  Or do I need to utilize a separate multiplexer?  I didn't come across I2C addressing info in your github.
Thanks for putting this out there!
CentyLab wrote 03/27/2025 at 20:12 point
Hi Eric. The main IC AP33772S only have one address so you will have to multiplex.
