The HPDL-1414 display is perfect for MCU/FPGA projects—it has its own embedded character ROM, so no need for custom fonts or segment mapping. Display module just require a 7-bit ASCII code on the data pins, and address to be set.
I paired it with a 74HC595 shift register board to keep pin usage low only 3 pins needed The result is a compact, solder-friendly display module and a separate ex-pander.
Data for the display is stored in a small memory block 16 bytes deep and continuously refreshed. To print data on the display we need to put the char in the memory that is done by verilog UART module.
Demo: Running on the icebreaker board.
Tx and Rx line are physically connected to the FPGA pins:
I was drawn to LEDs and old-school displays early on. One day, while browsing online, I came across bubble displays—particularly the beautiful HPDL-1414 alphanumeric displays. The aesthetics of these retro LEDs immediately caught my attention, and I knew I wanted to build something with them.
This is how my simple and fun project started. It’s a small, solder-friendly design that combines my passion for retro tech with modern usability.
The HPDL-1414 displays are both visually appealing and surprisingly easy to use. They’re smart displays, featuring an embedded character ROM that allows you to send simple 7-bit ASCII codes to display text.
By manually sending the data to data bus D0-D7 pins, and Digit position on A0-A1, charts can be already put on display.
source : https://www.farnell.com/datasheets/76528.pdf This simplicity makes the HPDL-1414 perfect for debugging, displaying outputs for FPGAs, or building devices using those retro led displays.
Prototype 0 conected to 595 shift registers and Arduino board.
The PMOD Board Design
To combine functionality with ease of use, I designed a small PMOD-compatible board that houses the HPDL-1414 displays. The board connects using two 12-pin PMOD connectors, making it ideal for use with FPGAs or microcontrollers. It’s simple, compact, and efficient—exactly what I wanted for a retro display module.
Pcbs arrived, and after very delightful and sort soldering process its ready to be tested
