The SD card contains a csv file with the RFID tag ID - User Name pairs, and it contains a csv log file as well. So the NodeMCU connects to the internet to get the correct current time. Then it waits for RFID tags. The OLED screen shows the name of the card's owner (and other debug messages). Finally NodeMCU saves the log to the SD Card. You can access the log through the webpage of the NodeMCU as well.
It is not an overoptimized project. Please help me with your suggestions to make it better.
RFID P1 PIN1 TX - NodeMCU D3 (It can be changed in the code.)
RFID P1 PIN2 RX - NodeMCU D4 (It can be changed in the code.)
RFID P1 PIN3 - - -
RFID P1 PIN4 GND - NodeMCU GND
RFID P1 PIN5 +5V(DC) - NodeMCU VV
+5V DC should be detached during firmware upload, because NodeMCU D3 is used also for FLASH.
SD Card SLOT - NodeMCU: SPI communication
SD Card Slot GND - NodeMCU GND
SD Card Slot +3.3V - NodeMCU 3V
SD Card Slot +5V - -
SD Card Slot CS - NodeMCU D8 (It can be changed in the code.)
SD Card Slot MOSI - NodeMCU D7
SD Card Slot SCK - NodeMCU D6
SD Card Slot MISO - NodeMCU D5
SD Card Slot GND - -
128x32 OLED Display - NodeMCU: I2C communication
OLED GND - NodeMCU GND
OLED VCC - NodeMCU 3V (!)
OLED SCL - NodeMCU D1
OLED SDA - NodeMCU D2
There is no OLED Reset pin on my OLED display. In the code we need to attache a pin number to OLED Reset. I choose D9. So I have no Serial Monitor, but I have everything else. It can be D0 as well, if there is no buzzer attached to D0.
Buzzer - NodeMCU
Connected as usual. Now between NodeMCU D2 - NodeMCU GND
NodeMCU D0 is used during flash of new firmware, so the buzzer needs to be disconnected during firmware update.
Please give me suggestions how to optimize these connections. How can I use for example A0, S3, S2, S1, SC, S0, SK, EN pins of NodeMCU?
Hello, the project is excellent. It works very well. I tried all the details. But I have a problem. How can I change the time difference (utc+3) according to the country I live in. Thank you
