Hackaday.io Hackaday.io
Sign up Log in
Vintage Tales from the Crypt LED Lamp Conversion
Converted a Broken Lamp into a new Collectable Item
neil-mundtNeil Mundt
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
0
0
1
Team (1)
  • neil-mundtNeil Mundt
Join this project's team
hardware
ongoing project
creepy Halloween tales from the crypt tales from the cryptkeeper scary stem led lamp
This project was created on 12/28/2024 and last updated a month ago.
Description
Converted this old 125v lamp into a Portable lamp that can be plugged in or used with a battery bank. Custom LED bulbs to fit inside the original wiring, and yes it was already quite broken when I found it at the thrift store. So I didn't really slaughter a Vintage collectable, kiddies. I also fixed it with epoxy. I'm planning on painting and sculpt it a bit more to give the Crypt-keeper more wrinkles. Planning to add more to this one of a kind Hybrid Diorama maybe The Crypt keeper needs some stories to narrate.
Project Logs
Collapse
  • Looking Better Then ever Just a little Cobwebs...
    Neil Mundt • 12/28/2024 at 00:32 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Official Hackaday Prize Entry
Create a magnetic 4 watt high power LED head lamp for applications like longboards out of an old hard disk drive for less than 25 $.
Project Owner Contributor
The Beamboarder
lyonLyon
The 2017 Hackaday Prize
A small battery-powered meditation aid to keep you focused and refreshed wherever you go. - Available on Tindie!
BreatheDot: A Portable Meditation Aid
ben-limBen Lim
The 2016 Hackaday Prize
Living in a Residential Bldg with long hallways & doors that all look the same, I tell folks to look for the door with the multi-color Ball.
DoorBall
grayson-schlichtingGrayson Schlichting
WiFi controller for RGB/RGBW Analog LED strips
nodeLED
mobilewillMobileWill
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Vintage Tales from the Crypt LED Lamp Conversion", please tell us the reason.
Send message
Remove Member
