MiniPico v1
A tiny handheld dev console, with a 12 button keypad, Pi Pico W inside, piezo buzzer, and 128x64 OLED.
This was an experiment to see how small I could make this thing. The hardware is 95% complete, except for a few small revisions I want to eventually make on the PCB.
Now I am working on the software. It will feature a new interpreted programming language. I wrote TGRK in C, this time I am writing GRK in Micropython. It's like a dream inside a nightmare!
A later implementation of GRK will be written in C.
GRK will be a variant of the GORK (General Optimized Reusable Keywords) programming language, which I still haven't finished. GRK is for (General Reusable Keywords), and will differ a bit from the other variants.
The main Idea for the device is to have a command line interpreter for GRK. A text editor. And a few utilities. I want to make some use of the WiFi onboard.
Project name has been changed from "Pico Picow" to MiniPico v1.
This device is actually quite simple. A Pi Pico W soldered directly to the PCB, 12 buttons, TP4056 IC and smd components, 14 pin female header for utilizing devices GPIO, and a 0.96" OLED display. As well as a slide switch for cutting the power.
I added some space on the back of the case for a small solar panel, but then I realized that I didn't design the PCB to allow that. If the voltage were high enough from PV, it would power on the Pico W through VBUS ( I need to double check if that is correct). So my solution was to print a snap fit cover for the back.
I think programming on this thing would be tedious, but much less tedious than programming on the Tiny Bit Machine... The programming language and interpreter I am writing for it has 3 key things in mind.
  1. How do we use the minimal amount of characters in our programs? When using an awkward keypad and programming on a tiny screen that is 8 rows of text 16 characters wide, we don't want to write long variable names or have to put in lots of punctuation or indentation. Ideally with how the GORK family of languages are written, they can be coded with almost no whitespace at all.
  2. It's easy to use. Why write a more complicated programming language than Python? Especially if I am writing it IN Python? GRK will be simpler than Python, therefore it will be lacking many features that Python or C have. But it will steal from both, as it is written in Python, which is written in C.
  3. It's portable. I intend to create a web interface or implement an FTP server on the device where files can be transferred easily to and from the device. Or be sent directly from one of these devices to another.
Below is the code for the current keymap, I will probably switch it around as time goes on. The idea is to have the most used keys on consecutive layers.
key_map = (('_esc','_caps','_esc',
                            '_space','_pgup','_pgdown',
                            '_del','_up','_enter',
                            '_left','_down','_right'),
                           ('0','1','2',
                            '3','4','5',
                            '6','7','_x',
                            '8','9','_mod'),
                           ('+','-','_x',
                            '*','/','_x',
                            '%','^','_mod',
                            '~','_x','_x'),
                           ('<','>','_x',
                            '!','=','_mod',
                            '&','|','_x',
                            '(',')','_x',
                           ('[',']','_mod',
                            '{','}','_x',
                            '`','_','_x',
                            '\\','_x','_x',
                           ('G','R','K',
                            'O','I','L',
                            '_x','.',',',
                            '_mod','@','$',
                           ('C','P','E',
                            '_x','S','D',
                            '_mod','M','U',
                            '_x','A','B',
                           ('_x','V','N',
                            '_mod','X','W',
                            '_x','Y','Z',
                            'J','F','W',
                           ('_mod','Q','T',
                            '_x','#','?',
                            '_x','\'','"',
                            'H',':',';',
The four buttons on left side of device and four buttons on right side of device are mod keys. If they are pressed and released quickly, they will function as the top layer key. If they are held down, they will activate that mod key's layer, and a tooltip showing the layer will popup on the screen as long as it is held. Here is an example:
  • Video of Project Current State
    Gordon01/21/2025 at 05:57 0 comments
  • Going Forward
    Gordon01/20/2025 at 18:07 0 comments
    I will be on a trip til the end of the month so will not be working on any projects during that time. But I have some thoughts on the future of this project and the interpreter as a whole.
    I am going to rename the language to just GRK. The initial version will be written in python, then I plan on making a version in C. Both implimentations will be available on my github in the same repository.
    I think micropython is fine for most cases on embedded devices such as Pico W if wanting to make something quick, or it's a small project. But as python is very inefficient on memory, with a larger project it is not very good. I am already having memory issues I need to sort out with what I have running  and it's really hard to track down where it's happening. So far it is almost entirely to do with using the urequests library for fetching data from the internet. I think I can optimize it in python, but if I were using C I doubt I'd have run into this issue yet as the total available memory would be much greater before even fetching the html request.
    When I wrote TGRK in C for attiny85, if I remember correctly I think the entire interpreter only used about 100-150 bytes of memory (not counting program memory, which in TGRK is set at 127 bytes). Granted TGRK does have a fraction of the features GRK will, but with this project, for it to work reliably I need to be able to manage the memory myself.
    A simple example is an integer variable for setting different modes. Let's say we have modes 0-3. In python this will automatically be several bytes. In C we can make sure it is only 1 byte by setting type as uint8_t. If we want 8 flags that can be 1 or 8, we can save that in a single byte and manipulate the bits in that byte. I need to lookup how many bytes micropython uses for a boolean. it has to be more than 1 considering how python stores variables.
    I have not used the C SDK for Pico or Pico W, so I will be setting that up and driving into that after the python implementation is finished.
  • Browser Based Programming
    Gordon01/17/2025 at 22:58 0 comments
    The title is just about one feature I've added, but there are a lot of new features, so many in fact I may forget about some.
    I have been having so much fun adding device features I have still not touched the interpreter.
    I will not list interpreter commands here as there are no new ones. But I do intend to make many or all of these system commands accessible from the interpreter.
    A picture of the browser tool:
    Below is the list of all system commands up to this point.
    Pico PicoW Device Specific Commands:
    s.w: If this command is run like this, and no ssid and password is currently set, it will scan for networks, then check if there are any saved networks that are available. if so it will automatically connect. If there is already a ssid and password set, it will try that first.
    • s.ws: Scans for available wifi networks
    • s.wc<n>: Connect to network "n" from scanned list. Acts the same as "s.w" if no argument provided.
    • s.wl: Display the scanned list of networks on screen
    • s.wx: Turn off wifi module
    • s.wa: Create a WiFi AP, prompts user for ssid and password.
    s.s: Creates a webserver, outputs IP address of server to screen. Webserver has a text area field that programs can be written into. If server receives program data, it replaces all the html characters with appropriate characters, and outputs it to screen. As of now it automatically appends to programs list. I will make this optional in future. As well add option for executing program immediately. Entering "end" into browser text area will shut down server.
    s.g: Currently running this as is will connect to "https://g0730n.com" and output "success" if it receives a 200 code back.
    • s.g<url>: Currently works the same as above, except any url can be fetched: "s.ghackaday.io"
    • s.gt: Fetches time from NTP server, updates system clock.
    • s.gw: Fetches weather data from API, saves data to text file as it is good for 48 hrs.
    s.t: Displays current date and time
    • s.ta: Non functional at moment, but will be used for alarms and timers.
    s.c: Displays weather graph of saved weather data.
    s.r: Not sure if is needed... Shuts down second core that scans keys, does a machine reset. Was having issues with connecting in Thonny so this was an attempt to deal with that. I did find a method that worked. So I dont think this is needed. But I will use this in future to do a reboot.
    s.z: Device sleep command, called as is without arguments, device will turn off oled, wifi, and enter deepsleep indefinitely. Pressing ESC button wakes device. RTC time does not increment in this mode. I have not tested yet, but this mode should only use 1-2mA of power.
    • s.z<n>: Turns off screen and WiFi as above, calls "time.sleep_ms(n)", n being 0-70 minutes. Will be used in alarm and timer modes in future. This method of sleep does not save a ton of power, but better than nothing. Drops machine.freq() to 20mhz before entering this sleep mode, then goes back to whatever it was before after finishing the sleep cycle.
    s.f<n>: Set the machine frequency. n being 20-250(mhz)
  • Experimenting With API's
    Gordon01/15/2025 at 16:14 0 comments
    Before I go back to working on the interpreter I decided to add some more system features.
    "s.g" can be used to fetch a URL if connected to the internet.
    "s.s" Will create a server and allow client to load a web page either over Pico AP or through LAN depending on Pico W's connection state. The web page has a single text area for writing a program and uploading to device. WIP
    "s.gw" will call weather API, get the next 48 hours of data. 48 data points of Temperature, Humidity, Cloud Cover, and Chance of Precipitation. The API I am using can be fined tuned for many different weather data points but these were what I thought I would find most useful.
    "s.c" will show a graph of this weather data:
    In the photo above the randomly scattered data points are from the cloud cover plot line. the lower it is on the screen the sunnier it is. The numbers on left hand side are for % of (clouds, humidity, chance of precipitation) or temperature in Fahrenheit.
    Connection to internet over wifi, on initial connection RTC time will be synced with NTP. This can then be retrieved by the command "s.t".
  • System Tools
    Gordon01/15/2025 at 01:55 0 comments
    I discovered that I didn't lose as much progress as I thought.
    Currently every feature that is available in the PC developement version is available and working on device.
    I am trying to figure out a good way to keep the interpreter separate from the devices code. In the sense that routines for handling the devices wifi connection or printing a line out to the OLED should be accessible from the interpreter while running on the device, but not while running it on PC.
    I decided to create an option from the device commandline to type
    "s.<system command>"
    Currently all I have implimented is a command line utility on device that can:
    1. [ s.wa] Create wifi AP, using a hard coded ssid and password or a new one
    2. [ s.ws ] scan for wifi networks. running this cmd saves a list of available networks
    3. [ s.wl ] view the list of networks saved in last scan
    4. [ s.wc<n> ] connect to the network of number specified from networks in list, this will prompt for a password. if command is run without a number, it will try to connect to the last saved network running [ s.w ] will do the same thing as   [ s.wc]
    5. [ s.wx ] turns off wifi, whether AP or Client, it goes off. I have it set up so only AP or client can be run at same time.
    I will later impliment a save file on flash that will have different saved settings including saved networks and passwords. when running [ s.w ] in that case it will automatically scan and see if there is a saved network that matches, then connect.
    I have also created a new function specific to the Pico Picow for easier printing of lines and getting input from anywhere in the devices code. While running the interpreter, the device is basically always stuck in an input mode. But I realized these system tools will need the ability for input that can be accessed out of the interpreters command line.
    I really want to get back to adding functions for the interpreter, but wanted to make sure 100% that it was all going to work on the device okay before I went any further. So far so good. I have a better backup system I am using right now too.
  • Version Control
    Gordon01/13/2025 at 17:00 0 comments
    I stayed up late last night working on the interpreter. I made a lot of really good progress. But this is real life and often times there is good news and bad news.
    I moved the entire interpreter into a class. I am not sure why I didnt start it out this way, but I realized it was inevitable and the longer I went without doing it the more tedious it would be.
    I spent a lot of time working on error handling, and was able to impliment and catch syntax errors that would before freeze the interpreter.
    I then decided to make the first port of the PC developement interpreter to the Pico Picow. This was also going great. It was exciting to finally be able to write commands on the devices console. I added a larger command history on the device, from it remembering the last command to remembering the last 8.
    And then as I was testing it on the Pico device, I went to save it again and somehow overwrite the last several hours of work. I know I was tired but this was unacceptable. I need to use a better version control than just saving multiple copies at random times. I did not lose all my work, just from wherenI started porting it to the device.
    So, these features I speak of exist, but I will have to re write them. Once I get back to where I was with the code, I will make a video as that was a good level of functionality to demonstrate the device.
  • Groups
    Gordon01/04/2025 at 23:34 0 comments
    Today I wrote the code for GROUPS, as I described in an earlier post that they are essentially functions that use the keywords G<n>  (n can be 0-99).
    I was having issues if I wanted to call a group from inside a group, where the last group would think it was creating a new group, but I figured that out, and now it's working as it should. Some example code:
    0K $Enter Your Name$
    G0@ O 0K I 1K O$Hello$, 1K,$!$ @
    G1@ G0 LG@
    G1
    This code demonstrates:
    1.  Storing a string into the KEYWORD "0K'
    2. Initializing the GROUP "G0", which does the following:
      1. Outputting retrieved KEYWORD 0K, which is the prompt for user
      2. Waiting for user input, which is stored in the KEYWORD "1K"
      3. A greeting as well as the users input is then output to user
    3. Initializing the GROUP "G1" which:
      1. Calls G0
      2. Loops G1
    I figured out how to make GROUPS callable from within other groups when I was coding TGRK. When calling a GROUP, a list holds the return address from where that GROUP was called from. When the called group reaches it's ending "@" symbol, it pops the last address from the list, which will be in the right order, and sets the program counter to that address.
    Below is an idea of several different ways we could write this code on the Pico Picow, either going for the most compact, or the most readable... keeping in mind 16 characters is the widest line that can be displayed on the screen:
    0K$Enter Your Na
    me$G0@O$Hello $,
    1K,$!$@G1@O0KI1K
    G0@G2@G1LG@G2
    0K $Enter
        Your
        Name$
    G0@
        O$Hello $,
        1K,
    G1@
        O 0K
        I 1K
        G0
    G2@
        G1
        LG
    G2
     To be able to format the code as above, I had to remove the feature where we can add whitespace by adding a space after the OUTPUT comma " O$Hi$, $there!$" will now output "Hithere!". I think that was a cool feature so I am going to look into some way of reintroducing it, but for now, just adding the space in the string literal or KEYWORD is enough.
    I think next I will work on Conditional Operators.
  • Debugging and Loops
    Gordon01/02/2025 at 23:53 0 comments
    I added a debugging function because it was getting crazy to debug when something went wrong. Parsing directly from a string takes a lot of steps. Now if I have debugging on, if there is an error I can see exactly what went wrong (sorta).
    I added the "L" and "LG" builtin KEYWORDS for LOOP and LOOP_GROUP. Here is how they work:
    0K 100 : <O 0K>  L
    @ <0K 100 : O 0K> LG
    The code enclosed with "< >" will be looped.
    "L" will scroll the program counter until it reaches a SEPERATOR ":" symbol.
    "LG" will scroll the program counter back until it reaches a GROUP "@" symbol, this allows for repeating a GROUP as many times as wanted. All KEYWORDS being global, effectively this can be very useful.
    it's pretty simple and works as intended.
    I also have assigning a value of a KEYWORD to another keyword setup:
    12K 2K
    The above sets the value of 12K to the value of 2K. I need to work on parsing math operators next. In the original GORK, my plan for the rules of math operators to be as such:
    1. A string KEYWORD or literal can only be added to or have something added to it, e.g. concatenation
    2.  If a string of keywords and literals are added together, and there is a string in there, the final result will be a string. If there is no string, if there are no floats, it will be an integer, otherwise it will be a float.
    3. Adding 1 to keyword 1K looks like this "1K + 1", there is no need for ++ or += or "1K = 1K+1" like in C or Python. The goal is to reduce as many characters needed to write a program.
      4K 12  - 2 + $ Day's until January $ + 12 + $th$
      [VALID:  4K  = $10 Day's until January 12th$ ) ]
      2K 128
      2K + 4 / 12 - 16 * 1.234
      [VALID: 2K  = 108.589]
      [INVALID OPERATIONS]
      4K $Howdy$ - 10
  • Once Again I am Writing an Interpreter From Scratch
    Gordon12/30/2024 at 10:51 0 comments
    My dream of writing a programming language that uses virtually no whitespace and as little symbols as possible is coming true.
    I have been playing around with the syntax a bit and found something to my liking. I will post a snippet of what I already have implemented and working in code, as well as a snippet of how I envision the larger syntax to look. It will look very similar to TGRK. TGRK was made the way it was for a very specific application. I think PGRK will be more universal.
    Once I have it fully written in Python, I plan on writing it again in C.
    On my Github, the original GORK programming language I started, I had the same concepts in mind that I wanted to accomplish, and was making some good progress on it, but, at the time, my knowledge of C was very limited. This was the second small project I was attempting after starting to learn C. So I ended up setting it aside, and started with MGRK, then that was too much, so moved on to SMGRK, which eventually turned into TGRK.
    Enough history, I will get those code snippets.
    The following piece of code will interpret and execute with the code I have running now, in any of the following whitespace configurations. Programming on a tiny device with a tiny screen, having the shortest possible keyword names as well as the ability to reduce whitespace to a minimum is a plus. Have you ever tried to read a large code page on a small screen? It is very frustrating.
    On the Pico Picow, the line widths will be fixed to a maximum of 16 characters wide. There are several reasons for this. At this point I don't think I want to enable any wrapping, or having any text reach off the screen. The point is to have it all visible, and miniaturized enough that a lot can fit on that 16x8 character page.
    0K20248K30O$Its December$, 8K,$th$, 0KI1KO1K
    0K 2024
    8K 30
    O $Its December$, 8K,$th$, 0K
    I 1K
    O 1K
     What we have here is basic KEYWORD (variable) storage and retrieval, as well as some input and output.
    Executed in the Python REPL, it outputs the following message, offers the user input which stores in the 1K KEYWORD, then outputs the message the user entered.
    Creating and assigning a KEYWORD is done with "<n>K<value>" n can be any number from 0-99, and the value formats are as following:
    An integer or float immediately following the K, or with any amount of whitespace between:
    3K2045
    3K 0
    3K        72
    3K 2.4928
    3K
    42
     The above are all valid. A string is created by using the $ symbol instead of quotes. It just made sense to do this.
    12K $This is a string.$
    12K
           This is another string. We can format
            however we want.
     Input will be like Python's input() function, which is completely blocking and can be typed into until the enter button is pressed. In PGRK, the input keyword is a single "I", immediately followed by the keyword we are storing the entered string into. I plan on adding keywords for getting individual keys and button presses for the Pico Picow, but as I am wanting to make a command line interface first, this will be helpful.
    I 1K
    The above takes input and stores it in the 1K keyword. It's that simple.
    Output is even funnier! Output is done with a single "O" followed by the data we want to send out. On the Pico Picow, this means it will be getting sent to a function that displays it on the OLED display. But for testing, it gets printed to the python command line.
    Output one value:
    O123
    Output two values, if there are more than one value to be sent out, they are separated by a comma. I was thinking about how I may or may not want to have spaces between these values. EASY. If you want a space, just add it after the comma. Adding more than one space will not add extra spaces. But if you don't want a space, don't add one and the data is contiguous.
    O $Hell$,0
     Output with spaces, also visualized how It would look trying to enter something that long on a small screen.
    OK3
    1K2
    O $Only$, OK, $d
    ays$, $until$, $
    January,$, 1K
    O $Only$, OK,
    $days$,
    $until$,
    $January,$,
    1K
     There is...
View all 9 project logs
