Pyk Long Range Communications Device
Have you ever sat down watching Stargate, and marvel at their long range communications device? Well live the dream here people!
After watching Stargate Universe I decided it was time to build my own long range communications device.
This device would, rather than take control of another person, just automatically dial them in Skype so you can communicate...over long distances....using a communications stone.
In the concept stage of this project the call numbers for your intended skype recipients are hard coded.
Once tests prove successful the webpage being served from the arduino will be upgraded to allow for configuring of 'stones' and also error checking and handling when stones are changed or added during an active call.
WebServer.ino
Arduino code to run long range comms device
ino - 5.86 kB - 03/07/2017 at 04:49
Download
  • 1 × arduino uno
  • 1 × Arduino RFID Shield
  • 1 × Arduino Ethernet Shield
  • 1 × Cat5e Cable
  • 1 × USB Cable Electronic Components / Misc. Electronic Components
View all 6 components
  • Hit a Wall
    Pike03/07/2017 at 04:52 0 comments
    So I am having trouble running javascript from the arduino webserver.
    I may have to create a standalone webpage that drags data out of the arudino published data.
    Will investigate, however have run out of time prior to SciFi contest submission.
  • Stage 1
    Pike03/07/2017 at 04:50 0 comments
    In stage 1 I managed to get the arduino communicating with the RFID tags, recording their value and publishing to a webpage.
View all 2 project logs
  • 1
    Step 1
    Install Skype & Arduino IDE
  • 2
    Step 2
    Connect Arduino, Ethernet shield and RFID Shield
  • 3
    Step 3
    Upload program code and run
View all 5 instructions
