For a while I was wanting to buy a Logitech G29 wheel set. Naturally, I decided to spend alot of money on a Fanatec CSL DD combo instead so I wanted to make a handbrake out of stuff I have lying around my house. I hoard alot of random parts so with some digging around and some 3D printed supporting parts, this came out to be essentially a "free" project for me. It wasn't really free because I bought all this stuff at one point but I managed to avoid buying any additional parts.
Rather than a DIY project, this is more of a DIM project (do it MYself), simply because it would not be worth it for someone to go out and buy all the parts just to make this. If you think about it, this is just a giant 1 axis joystick made out of garbage. I do hope this project can serve as inspiration for people trying to make their own sim racing peripherals. If you are looking for a tutorial type project, there are better performing and likely cheaper options out there.
I think a fully 3d printed (or machined) project would be much cleaner, but the constraints of having to incorporate off the shelf brackets and parts makes the design process more fun.
I hope to keep this project on going for now because even though the first iteration works, there is always room for improvement.
Now I need to make a place for the magnet and all the electronic components. It would be cool to route the wires through the hole in the front of the base that is typically used by a motor shaft, but I'm not sure if there will be enough room.
Maximiliano Palay
Adam Smallcomb
zapwizard
Oscar S.
