The clock consists of 4 modules of digits paired in two units. Each pair is powered by a 20mm geared stepper motor. Each pair has one module driven by the stepper motor and the second module is moved by a carryover mechanism. Both the units are controlled by a control board in the base containing a atmega8 running in the arduino ecosystem.
The single module
The entire assembly of 4 modules
The base
It contains the control board which consists of a Atmega 8 and a pair of a4988 stepper drivers
the complete drawing
Richard
Bastien
Pattern Agents
MinerMiller
Now we just need elasticated EL wire
