testing a dual module with carryover
A project log for BEZICRON
A 3dprinted electro-mechechical clock with flexible digits
ekaggrat-singh-kalsiekaggrat singh kalsi 01/10/2025 at 05:510 Comments
next I assemble a dual module to test the carryover mechanism. I worked smoothly as the 20mm geared stepper is a overkill for this purpose. The units motor homes to zero using the hall sensor and then runs clockwise to change the digits. After every one turn it carryovers to the tens module using a carryover gear mechanism.
