This project is called Borneo-Iot, it's the most advanced open-source, multi-segment dimmable, high-power, smart WiFi LED light designed for aquariums.
It's not a LED strips driver but a constant current high-power multiple channel LED.
What’s included in this project?
- Open source mobile app serving as a universal wireless device user terminal
- Wireless 6-channel LED PWM embedded controller module (core board)
- Firmware developed using ESP-IDF
- 5-channel LED aluminum PCB reference design for the controller module
Everything is Open-Source
The Borneo-IoT Project is an open-source hardware initiative, running with open-source firmware and provides an open-source mobile client app. All source code and design files are available on GitHub.
Files
blc06mk1_sch.pdf
The schematics of BLC06MK1 module.
Adobe Portable Document Format -
255.88 kB -
02/01/2025 at 17:18
