This is the challenge of NASA’s Synthetic Biology project. The goal is to design a bioreactor that can be reused and recycled for use in space. I created the project to document the process. There is a lot of information to learn, so I researched the documents in the link provided by the project, and also studied the video recording the actual operation process on the ISS space station.
I also discussed with the project representative to get more technical parameters that I did not understand clearly.
Continue working...
