#2 Project log
A project log for Design Bioreactor for Deep Space Food Production
tranvinhquangTRAN.VINH.QUANG 01/23/2025 at 16:380 Comments
I kept thinking while drinking the milk in my hand, I looked at the milk and thought about how astronauts eat in space. The information from the project showed that there was a type of yogurt created from a bioreactor, which could be used for eating.
My observations showed that the food was contained in plastic packaging, after adding hot water, it was torn open and then eaten with a spoon, there were special trays, possibly magnets and strings to keep the food bags from floating and flying around. These plastic bags seemed to be used only once based on the tear marks I observed.
I continued to consider the principle and design as well as the first test version of the low-weight coffee cup.
I came up with the idea of a flat design that simulates the food bags that astronauts often use, with a curved bottom to keep food from spilling out when moving in space, and I wanted to test the zip lock style so that it could be reused, when loading ingredients or opening it for use, just open the lock, when finished using, you can close the lock and the bag can return to its original shape, the only thing I need to learn more about when reusing is the hygiene part. I can use the luer lock as a water inlet port and also as a gas outlet port from the biological reaction.
The thickness of the bag can be from 0.1-0.3mm to reduce weight and fit the 3d printer head, and the thin bag can be recycled by cutting it into thin strips to pull into raw material strings for 3d printing of other items.
Start manufacturing.
[Tiếng Việt]
Tôi cứ suy nghĩ mãi trong khi uống bịch sữa trên tay, tôi nhìn bịch sữa và nghĩ đến việc các nhà du hành vũ trụ ăn uống thế nào trong không gian. Thông tin từ dự án đưa ra có một loại yogurt được tạo ra từ buồng phản ứng sinh học, có thể dùng để ăn.
Các quan sát của tôi cho thấy, thức ăn đều được chứa trong các bao bì nhựa, sau khi tiếp nước làm nóng thì xé ra sau đó dùng thìa để ăn, có các khay đặc biệt, có thể là nam châm và dây giữ các túi thức ăn không bị trôi nổi và bay loạn xạ. Các túi nhựa này dường như chỉ được dùng một lần dựa theo vết xé mà tôi quan sát được.
Tôi tiếp tục xem xét về nguyên lý và thiết kế cũng như bản thử nghiệm đầu tiên của chiếc cốc cà phê trọng lượng thấp.
Tôi nãy ra ý tưởng là một thiết kế dẹp mô phỏng các túi thức ăn phi hành gia hay dùng, cong phần đáy để giữ thức ăn không trào ra khi di chuyển ngoài không gian và tôi muốn thử nghiệm kiểu khóa zip để có thể tái sử dụng lại, khi nạp nguyên liệu hay mở ra sử dụng chỉ cần mở khóa, khi dùng xong có thể đóng khóa lại là túi có thể trở về hình dạng ban đầu, duy chỉ có phần vệ sinh là điều tôi cần tìm hiểu thêm khi tái sử dụng. Tôi có thể dùng khóa luer là cổng tiếp nước đồng thời làm cổng thoát khí từ phản ứng sinh học.
Bề dày của túi có thể từ 0.1-0.3mm để giảm khối lượng và phù hợp với đầu in 3d, đồng thời túi mỏng có thể tái chế bằng cách cắt thành các dải mỏng để kéo thành dây nguyên liệu dùng cho in 3d các vật dụng khác.
Bắt đầu chế tạo.
