Now for some code, I will add the final version later as there are a pile of additional timer routines but for now I am testing the stability of the system. There seems to still be some RFI issues when the spin cycle ends and the actuator drops the brake but I also ran out of parts to make a snubber for the actuator so this fault should go away once the additional snubber is n place.
Yes i know its full of while loops but I wanted this to be as simple as possible for testing purposes.
#include <Bounce2.h>
// Constants for Control Pins
const int LedPin = 13; // LED Pin
// Washingmachine Sensor Pins
const int WaterLevelPin = 2; // N/C Switch to sense the water level If it goes open then stop everyting.
const int LindSwitchPin = 3; // Goes OPEN circut if the lit is opend. E-STOP
const int SpinSensorPin = 12; // When the spin locking pin is in place this is short
// IN# are the relay inputs for the Duinotech 8 Channel Board
const int CWPin = 4; // IN1 - Clockwise Pin
const int CCWPin = 5; // IN2 - Counter Clockwise / FAST SPIN Pin.
const int SpinActuatorPin = 6; // IN3 - Pull the locking pin in for the spin cycle
const int ColdWaterValve = 7; // IN4 - Cold Water Valve
const int HotWaterValve = 8; // IN5 - Cold Water Valve
const int WaterPumpPin = 9; // IN6 - Water Pump
// Control Pannel Pins
const int StartPin = 10; // Restart After and Error
const int RestartPin = 11; // Restart After and Error
// Control Variables
int ledState = LOW; // ledState used to set the LED
int CWState = LOW; // Clockwise Relay State
int CCWState = LOW; // Counter Clockwise Relay State
int SpinState = LOW; // Spint Actuator State
int ColdState = LOW; // Cold Water Valve State
int HotState = LOW; // Hot Water Valve State
int PumpState = LOW; // Water Pump State
int incomingByte = 0;
int MachineCycle = 0;
int WaterLevel = 0;
int SpinEnabled = 0;
long AgitationCounter = 0;
long BallanceCounter = 0;
long RinseCounter = 0;
long SpinCounter = 0;
long EmptyWater = 0;
long SoakCounter = 0;
// Instantiate a Bounce object
Bounce debouncer = Bounce();
void setup() {
Serial.begin(9600); // Serial Communications for Debuging
pinMode(StartPin,INPUT_PULLUP); // Pin to use for the Start Button
debouncer.attach(StartPin); // After setting up the button, setup the Bounce instance :
debouncer.interval(40); // interval in ms
// set the digital pin as output:
pinMode(LedPin, OUTPUT); // Onboard LED on pin 13
pinMode(WaterLevelPin, INPUT_PULLUP); // Enable Pullup for WaterLevel Sensor
pinMode(LindSwitchPin, INPUT_PULLUP); // Enable Pullup for Lid Switch
pinMode(CWPin, OUTPUT); // Clockwise Motor Control
pinMode(CCWPin, OUTPUT); // Counter Closkwise Motor Control
pinMode(SpinActuatorPin, OUTPUT); // Spin Actuator Solinoid
pinMode(ColdWaterValve, OUTPUT); // Cold Water Valve
pinMode(HotWaterValve, OUTPUT); // Hot Water Valve
pinMode(WaterPumpPin, OUTPUT); // Water Pump
pinMode(StartPin, INPUT_PULLUP); // Start Button
pinMode(RestartPin, INPUT_PULLUP); // Restart/Resume after Error
pinMode(SpinSensorPin, INPUT_PULLUP); // Enable Pullup for Spin Sensor
void loop() {
debouncer.update(); // Update the Bounce instance :
int value = debouncer.read(); // Get the updated value :
if ( value == LOW ) {
Serial.println("Washing Cycle Started");
MachineCycle = 1; // If the button is pushed start the machine
// send data only when you receive data:
if (Serial.available() > 0) {
incomingByte = Serial.read(); // read the incoming byte:
Serial.print("I received: "); // say what you got:
Serial.println(incomingByte, DEC);
if(incomingByte == 48){
Serial.println("Stop Machine");
MachineCycle = 0;
// If we receive a 1 run this
if(incomingByte == 49){
Serial.println("Start Machiner");
MachineCycle = 1;
if(MachineCycle == 1){
Serial.println("Filling Machine with Cold Water for Wash Cycle");
while(digitalRead(WaterLevelPin) != 1){
//Fill the machine
digitalWrite(LedPin, HIGH); //Start Filing
digitalWrite(ColdWaterValve, HIGH); //turn on the cold water valve
if(digitalRead(WaterLevelPin) == 1){
digitalWrite(LedPin, LOW); //Start Filing
digitalWrite(ColdWaterValve, LOW); //turn on the cold water valve
Serial.println("Machine filled with water");
WaterLevel = 1;
//3 minutes = 180000
Serial.println("Agitating Washing");
while(AgitationCounter <= 80){
digitalWrite(CWPin, HIGH);
digitalWrite(CCWPin, LOW);
// Serial.println("Agitate CW");
delay(800);
digitalWrite(CWPin, LOW);
// Serial.println("PAUSE");
delay(800);
digitalWrite(CCWPin, HIGH);
// Serial.println("Agitate CCW");
delay(800);
delay(800);
AgitationCounter++;
//Serial.println("Agitating Washing");
//Serial.println(AgitationCounter);
Serial.println("Soaking for 1 minute");
SoakCounter = 0;
while(SoakCounter != 60){
delay(1000);
SoakCounter++;
Serial.println("Agitating after soak");
while(AgitationCounter <= 60){
delay(700);
delay(700);
delay(700);
delay(700);
AgitationCounter++;
Serial.println("Preparing to Spin");
while(digitalRead(SpinSensorPin) != 0){
digitalWrite(SpinActuatorPin, HIGH);
// Serial.println(digitalRead(SpinSensorPin));
//This will deal with the weird bounce issue from the actuator
delay(1000);
if(digitalRead(SpinSensorPin) == 0){
SpinEnabled = 1;
// Serial.println("Spin Enabled");
Serial.println("Ballance Load");
while(BallanceCounter <= 10){
delay(1000);
delay(1500);
BallanceCounter++;
// Start emptying the water
Serial.println("Ballance Load and Drain");
EmptyWater = 0;
while(EmptyWater != 70){
digitalWrite(WaterPumpPin, HIGH);
delay(1000);
delay(1000);
EmptyWater++;
// Start a Full Speed Spin Cycle
Serial.println("Spin and Drain");
SpinCounter = 0;
while(SpinCounter != 70){
delay(1000);
SpinCounter++;
// Start Spin Rinse
Serial.println("Spin and Rinse");
RinseCounter = 0;
while(RinseCounter != 40){
delay(1000);
delay(1000);
RinseCounter++;
//Make sure the water is OFF
// Finish high speed spin
SpinCounter = 0;
Serial.println("Final Spin");
delay(1000);
SpinCounter++;
// Spin Down and turn pump off
SpinCounter = 0;
Serial.println("Slow Down");
while(SpinCounter != 20){
digitalWrite(WaterPumpPin, LOW);
delay(1000);
SpinCounter++;
// Release Spin Actuator
digitalWrite(SpinActuatorPin, LOW);
//Reset the water level
WaterLevel = 0;
//MachineCycle = 2;
Serial.println("Washing Machine Stopped");
Serial.println("Go top the final wash cycle");
Serial.println("Filling Machine with Cold Water for Final Wash Cycle");
//Fill the machine
WaterLevel = 1;
delay(700);
delay(700);
delay(700);
delay(700);
AgitationCounter++;
SoakCounter = 0;
while(SoakCounter != 12){
delay(1000);
SoakCounter++;
delay(700);
delay(700);
delay(700);
delay(700);
AgitationCounter++;
delay(1000);
SpinEnabled = 1;
delay(1000);
delay(1000);
BallanceCounter++;
EmptyWater = 0;
while(EmptyWater != 80){
delay(1000);
delay(1000);
EmptyWater++;
SpinCounter = 0;
while(SpinCounter != 80){
delay(1000);
SpinCounter++;
// Start Spin Rinse
RinseCounter = 0;
while(RinseCounter != 20){
delay(1000);
delay(1000);
RinseCounter++;
SpinCounter = 0;
while(SpinCounter != 60){
delay(1000);
SpinCounter++;
SpinCounter = 0;
delay(1000);
SpinCounter++;
WaterLevel = 0;
MachineCycle = 0;
}//Machine == 2
Boris van Galvin
