Intro
ZigMo is a 4 channel Zigbee soil moisture meter. The project pursues 2 goals:
- Hardware: Attempt some very basic electronic engineering and build a Zigbee device based on a custom PCB.
- Software: Write a custom firmware for the device that would make the Zigbee thing work.
Description
The concept is pretty simple. It is a Zigbee end device with 4 capacitive wire connected moisture sensors that you could stick into 4 nearby flower pots and monitor moisture levels in all of them with a single device.
This is what it looks like in Home Assistant:
The device is based on a popular CC2530 module that can be bought off Aliexpress for about $3. Custom PCB part handles battery power, routes connections to individual moisture sensors, provides debug connectors and implements user interface - a LED and a button.
Build notes
PCB:
The PCB was designed in KiCad and then ordered from JLCPCB. All parts are common and can be ordered from your favorite parts supplier.
Note: I know nothing about electronic engineering and have no experience with PCB design. I just watched some video on Youtube on how to do it.
Firmware:
The firmware is based on Zstack 3.0.2. It simply queries the moisture sensors and measures battery voltage every 5 minutes.
ZStack SDK is available for free from Texas Instruments. It contains several examples and even a guide on how to branch your own project off one of those examples (Z-Stack 3.0 Sample Application User's Guide.pdf). The most challenging part IMO is getting the IDE/Compiler. ZStack 3.0.2 applications should be built using IAR studio for 8051 processors version 10.20. This IDE is not free, however a free trial is available. You may find other ways of getting it if you search hard enough.
See also
- Book: Drew Gislason - "Zigbee Wireless Networking"
- Very cool and super detailed series of posts on how to build a Zigbee device from scratch based on the NXP Zigbee stack: https://github.com/grafalex82/hellozigbee
- A bunch of ZStack Zigbee projects built at very professional level: https://github.com/diyruz
hello42world
Tim Wilkinson
Slaven Damjanovic
Sahas Chitlange
Chris Lee
You are welcome! You might want to check out these posts as well. There is a lot of good info on waterproofing such sensors.
https://medium.com/@d.robertson/protecting-capacitive-soil-moisture-sensors-e1ab81f1c4fb
https://thecavepearlproject.org/2020/10/27/hacking-a-capacitive-soil-moisture-sensor-for-frequency-output/
