GLOBO
Globo: A High-Altitude Balloon for Environmental Monitoring and Climate Research
Rising greenhouse gases like CO₂ and methane drive global warming, making accurate, real-time data crucial for identifying high-risk areas and developing solutions. High-altitude CubeSats offer a sustainable and scalable way to monitor greenhouse gases and atmospheric conditions, filling gaps left by ground-based systems and informing climate action strategies.
Our CS 12 team is designing and deploying GLOBO, a high-altitude CubeSat equipped with sensors to monitor humidity, temperature, CO₂ levels, methane, and pollutants, alongside visual observations. The prototype includes GPS tracking, a robust communication system, and a 3D-printed payload frame to ensure reliability in challenging conditions.
The project demonstrates the potential of high-altitude balloons in advancing climate research. By addressing gaps in pollution tracking and its environmental impacts, GLOBO provides insights into local pollution trends, their sources, and effects on climate change.
Project Overview
Portable Network Graphics (PNG) - 197.67 kB - 01/31/2025 at 04:41
Preview
Technical Overview
Portable Network Graphics (PNG) - 252.39 kB - 01/31/2025 at 04:41
Preview
  • Light APRS Update
    Stephanie Wallen6 days ago 0 comments
    We are working on integrating an APRS module into our sensor system. We have minimal experience working with this kind of device, so we are trying to learn using online resources.
  • Successful Integration of Carbon Monoxide Sensor
    Stephanie Wallen02/06/2025 at 06:42 0 comments
    We successfully integrated an MQ-7 Sensor onto our Arduino system. This sensor measures Carbon Monoxide and will be useful for environmental studies.
  • Housner Fund Update
    Stephanie Wallen02/05/2025 at 18:21 0 comments
    We are so excited to share that we have been granted money from the Housner Fund to complete our project. This will allow us to purchase the parts that we need to make this project a reality. We are grateful for the support, and are excited about the future of this project.
  • Successful Integration of Clock, Sensor, and SD Card Reader
    Stephanie Wallen02/05/2025 at 18:16 0 comments
    Using the Arduino Uno we successfully integrated the clock, sensor, and SD card reader. The real time clock will allow us to keep track of when measurements are being recorded. The sensor, a BME 688, allows us to get measurements like humidity, temperature, and altitude. Finally, the SD card will allow us to transfer this data back to our computer. Attached is the photo with our weather readings and their corresponding time stamp.
  • Successful SD Card Data Upload
    Stephanie Wallen02/03/2025 at 07:06 0 comments
    We successfully transferred data from the Arduino onto the SD card and opened the data using an SD card reader on another computer. We also successfully uploaded the data from the sensor onto the SD card.
  • Parallel Circuit
    Stephanie Wallen02/03/2025 at 06:39 0 comments
    We are setting up a parallel circuit so that the SD card reader and the sensor can both get 5V using the same port.
  • Successful BME 688 Test
    Stephanie Wallen02/03/2025 at 06:01 0 comments
    We circuited the BME 688 sensor and used open source code to program it. We got successful temperature, pressure, and altitude readings.
  • Project Update
    Stephanie Wallen01/31/2025 at 04:49 0 comments
    The primary purpose of this project is to create a functional prototype that demonstrates how high-altitude balloons can be leveraged for environmental monitoring and climate research. By equipping our high altitude balloon with sensors for CO₂, aerosols, and infrared temperature variations, we aim to address critical gaps in pollution tracking and its environmental effects.   To make this project a reality we need funding. Our anticipated budget is less than $1,000, since we have a simple one unit payload design. In comparison, other high altitude balloons usually cost over $5,000. We have applied to the George W. Housner Student Discovery Fund to hopefully get the financial resources we need for this project.
  • Sensor and Components Breakdown
    Stephanie Wallen01/31/2025 at 04:43 0 comments
    • Humidity: Utilized to monitor moisture variations at different altitudes.
    • Temperature: Incorporated to capture thermal gradients and analyze heat distribution across the altitudes.
    • CO₂ Concentrations: Using an infrared absorption sensor to monitor atmospheric CO₂ levels and identify pollution trends.
    • Methane: Detected to accurately measure methane concentrations, a key greenhouse gas.
    • Combustible and Hazardous Gases: Utilizing sensors to detect a range of volatile organic compounds (VOCs) and hazardous gases that may indicate pollution sources
    • Camera: Record the launch and observe any visible changes
    • GPS Tracking System: A high-precision SPOT GPS receiver for real-time monitoring and transmission of the balloon’s geolocation and altitude
    • Communication Module: A dedicated communication system (e.g., RF transceiver or APRS) for seamless data transmission to a ground station, to prevent losses of data
    • Payload Frame: A custom-engineered structural frame (3D printed) designed to house and protect all components under varying environmental conditions.
  • Project Objective
    Stephanie Wallen01/31/2025 at 04:41 0 comments
    With rising levels of greenhouse gases like CO₂ and methane driving global warming, obtaining real-time, accurate data on these emissions is essential to pinpoint high-risk areas and develop effective solutions. Particularly, in light of recent fires, studies of atmospheric emission footprints are essential to environmental research efforts.
    High-altitude CubeSats are a sustainable, cost-effective, and scalable way to monitor greenhouse gases and monitor atmospheric conditions. By deploying advanced sensors in the upper atmosphere, CubeSats continuously gather data in real time, filling the gaps left by ground-based monitoring systems. These important insights can inform policy decisions, improve environmental management, and enable more targeted actions to combat climate change. Thus, greenhouse gas and environmental monitoring high-altitude CubeSats are crucial for addressing the growing challenges of climate change and environmental degradation. Inspired by this growing need, we aim to design, prototype, and deploy a high altitude CubeSat GLOBO equipped with advanced sensors for monitoring atmospheric conditions and pollutants.
    Our project entails the design and deployment of a high-altitude balloon prototype equipped with an array of environmental sensors for comprehensive atmospheric data collection and transmission.
View all 10 project logs
